Question about DeLonghi DC60T Coffee Maker
Coffee machine is leaking from bottom
When I fill the coffee machine with water,watching I don't spill the water,before I turn the machine on,It's leaking from underneath.
    Genius:
  • 1,074 Answers
The rubber seal for your coffee machine need to be replace.
Posted on Mar 30, 2007
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
How do I fix a leaking Bunn Coffeemaker model NHBX-B?
This is a home model pour over. Overfilling is the most common cause of leakage as there is no plumbed in water line. You should only pour in the amount indicated on the decanter. If it is overflowing, check if you have the right decanter as someone may have used an old pot from a larger brewer. Say there was a 12 cup pot around and now you have a 10 cup brewer.
* carefully pour water to the inner fill line. You will probably see a ledge or spill off hole on the inside of the fill tank. Some units will spill out the back, others may spill back into the drip funnel. Note at what point you get near the spill level and note how much is left in the decanter. The amount left is your over flow.
* If you want more accuracy then use a measuring cup and count how many cups are needed to fill the brewer.
* Unplug any brewer that has water coming from the base. Dry up the area and drain the brewer. Dry off and let sit to completely dry out. Refill, note any leaks? If okay then plug in and brew as normal.
* still having problems? Contact your vendor for service.,
Aloha, ukeboy57
Jun 30, 2015 | Bunn NHB Coffee Maker
Water leaks from the top of the right side of commercial coffee maker
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Apr 03, 2014 | Bunn VPR Coffee Maker
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
My Espresso Machine leaks out the bottom
thier is a puddle of water that leaks out of the bottom of machine after i brew my expresso
Dec 29, 2012 | Mr. Coffee ECMP40 Espresso Machine
Hi, I purchased Rancilio Silvia v3. I have overflow of water in water tank. What happens and how can I fix? Thank you.
There is a max fill line mark on the side of the water tank. Fill the water to there or less. Do not fill the water any higher than this line or water will spill out the side where the water inlet hoses run. Also make sure that the tank is not cracked and leaking water.
Apr 26, 2011 | Rancilio Silvia Espresso Machine
Need to fill resivoir how much
Unplug coffee pot, empty over sink, turn on to ensure it has pumped all water out, turn off, refill with water, restart normally.
Sep 05, 2009 | Krups FME2 Coffee Maker
I have a BUNN VPS that leaks water when we make coffee. I have removed the top of the maker and watched, but I can not see the leak.
There is a significant amount of plumbing inside one of these. I think it will have to be taken apart to find the leak -- these leaks are very common and sometimes very difficult to stop (kinda like a roof leak).
Apr 21, 2009 | Bunn VPS Coffee Maker
Water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Apr 12, 2009 | Bunn 10 Cup Home Coffee Brewer
Coffee is not flowing thru system
you anti leak valve or leak stop in the bottom of your filter holder is broken. You can pull it out with no problem . Leaving you with no drip stop but your coffee will go into you decanter
May 25, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
DeLonghi DC60T Coffee Maker Logo
764 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
