Question about Lexmark JetPrinter X1185 All-In-One InkJet
My ink cartridges won't move to the center when I open the printe
I have a lexmark x1185 all in one and I want to replace the cartridges..When I open the printer the ink cartridges do not move to the center...Any ideas?
  • luvnlowes Dec 19, 2008
    The power is on to the printer. The printer starts up but when I open the top to replace the cartridge the cartridges won't come to the center.
    Master:
  • 461 Answers
Be sure the printer is powered on as it needs power to move the cartridges - this is a common mistake.
Posted on Dec 19, 2008
  • Curtis Richner Dec 19, 2008
    Here are the instructions as per the User Guide.
    1 Make sure the All-In-One is on.
    2 Lift the scanner unit until the scanner support keeps it open.
    The print cartridge carrier moves and stops at the loading position
    unless the All-In-One is busy.
    3 Squeeze the tabs on the cartridge lids, and then lift the lids.
    4 Remove the old cartridges. Store them in an air-tight container or
    dispose of them.
    5 If you are installing new cartridges, remove the stickers and
    transparent tape from the bottom of the cartridges.
    Warning: Do not touch the gold contact area on the cartridges.
    Maybe something is is keeping the switch or sensor from incating it is open or its not opening all the way.
I had a similar problem with my printer. It's also a Lexmark so I'll share the solution I found, although I can't guarantee it will work on all models. If the cartridge unit won't centre but appears partially from under the side covering (perhaps just for a second) you can grab it and drag it across to the centre, then unload the old cartridge and put the new one in. Not very delicate, I know, but it worked.
Posted on Jul 06, 2009
  • Paul Mankus
    Paul Mankus Jun 03, 2012
    A friend that I'm trying to assist is also having this issue. I was tempted to try the grab method, but not sure I wanted to do it in front of them! Maybe I can take it home and "service" it there. Thanks for the tip!
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
I ddon't know how to get the printer to recognize the color ink that I have installed. The printer will not print.
Make sure you are inserting the correct cartridge for your model. Try to clean the print cartridge nozzles using the computer. Load plain paper. Open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center). From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles. Try to print your file again and check it's properly printing now.
May 04, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Lexmark X1185
If the ink cartridge is not empty it is probably clogged. The Print nozzles are very sensitive and cleaning attempts can make the situation even worse if carried out wrong. You can try cleaning with dry gas alcohol as it contains no water. Use a piece of leather sham or other non lint material like eyeglass lens cleaner wipes and the dry gas. Wet your cloth and gently hold it on the print nozzles allowing the alcohol to dissolve the dried ink in the nozzles. Do not rub hard or you will ruin the print head. Hold it in place for at least 2 minutes with a generous amount of alcohol in the cloth. Imm
ediately place the cartridge in the printer and perfom the clean nozzle function.
If this does not remedy your problem the print cartridge must be replaced. Hope this helps you out.
George
Jun 10, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark All in one printer
looks like you may need to replace the black cartridge.
usually when you open the cover of your printer, cartridge carrier will move to the center. that's where the cartridges are, you can open it buy pushing it down and release it.
you can also checked lexmark site for this
check out this link too.
x1185 and x1100 are most likely the same.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Mar 26, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
1,264 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
