Question about Acer Computers & Internet
I just bought the Acer Aspire One mini netbook, and I cannot configure it, because where I am now does not have wireless access. I need to turn it of and I don't know how. I depressed the power button and it won't turn off. Please help
    Sergeant:
  • 279 Answers
HOLDING the power button down will usually shut it down, but you really need to shut down by Windows.
Reply if you need more help.
Hope this helps.
Posted on Mar 08, 2010
How can I get my acer aspire one mini laptop to access wifi?
Connecting your Acer laptop to your home wireless network is fairly simple. Before you begin you need to know the SSID broadcast name (Wi-Fi) network name and security passphrase (Wi-Fi network password).
Move the Wi-Fi switch to the "On" position. Not all models have this switch. Open the Windows Start menu and select "Connect To." A list of available connections will appear. Select "All" from the drop-down menu to view all available networks and connections within range. Select the desired network and click "Connect." Enter the security passphrase if prompted and click "Connect" again to join the network and gain wireless Internet access.
Wireless configuration for your laptop http://en.kioskea.net/faq/294-wi-fi-wireless-configuration-for-your-laptop - for-acer-users
Feb 21, 2013 | Acer Aspire One AOA150-1949 Laptop
I bought 2 Acer Aspire one netbooks and I can't get either one to connect to wi-fi. They show strong connectivity to the wireless network, but no internet?
you are seeing it strongly connected to the ROUTER---try unplugging the router for a few minutes and plug it back in----Does the netbook "SEE" the network? entered correct ssid? Is the wireless switch enabled on the netbook?
Dec 24, 2010 | Acer Aspire One Netbook
I have an ACER Aspire notebook. Its new wireless
ip settings,, may be ur getting a bad ip or ur dhcp is not configured properly... reset tha router and reconfigure it
Jan 16, 2010 | Apple AirPort Extreme Base Station...
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.
With an Ethernet cable, connect from the netbook to a LAN port on the 2WIRE modem.
Access the built-in web-server on the 2WIRE modem, and configure the "wireless network settings" to your choice of SSID and network password/passphrase.
Then, from your computer, "View Available Wireless Networks",
and connect to the SSID that you have chosen.
Dec 29, 2009 | Acer Aspire One PC Notebook
Acer aspire one 8.9 wireless wont work
First make sure the wireless card driver in the computer is installed and the wireless is enabled and working.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Nov 29, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Cannot connect acer aspire one to my tp-link router
go start run type services.msc then go down to the bottom click zero wireless configuration then click start and you should be good to go
Jul 14, 2009 | Acer Aspire One A150-1672 Notebook
I just bought a acer aspire one, and i cant get my sprint wireless internet to work with it.
first of all the mini is limited with external acessories i you want to carry extra luggage around its better to get a regular laptop
Jun 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Netbook is "Connected" but can't use internet
You first need to establish that you have internet available to your router via cable modem, dsl, etc. Unless your modem is also your wireless router. Take your ethernet connection or cable that resembles a large phone cable and plug in your Acer One directly into the router. You should then be able to get internet. If not, you may have a problem with your internet in general and need to contact your Internet Service Provider. Also if possible try another pc, see if it has internet. Lastly try reinstalling wireless diver in device manager.
Mar 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Have ACER ASPIRE ONE MINI PC, have broadband service can't get
Mar 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dropped Wireless connection on Aspire One 8.9" Netbook
make sure your isp is suppling your 2nd ip address...
Dec 25, 2008 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
