My Vista System no longer sees my DVD RAM 425Gv1 USB player/burner. My system cannot find drivers on my system or on my Vista upgrade disc.
    Master:
  • 461 Answers
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Posted on Dec 19, 2008
External disc reader/ burner
Short answer: Yes, it will.
Slightly longer answer: 3 things will be important:
1) The version of USB your computer has will matter (the higher the version, the better; recommend a minimum of USB 2.0)
2) The version of operating system is important. Assuming you're on a Windows/Intel-based system, XP would be the lowest/oldest OS that would be practical
3) Speed of processor and amount of RAM plays an important role here too - again, higher number on the processor, and more RAM will (generally speaking) provide a better experience.
Oh, and depending on what you want to do with it, you'll need software, such as CD/DVD authoring software (try www.tucows.com).
Jun 01, 2012 | Acer Computers & Internet
Anyone know where to get the drivers for my LG lightscribe burner GSA-E30L ?
Windows XP/Vista/7 operating systems have the driver for all disc drives build in. If it isn't working, then the driver is not your problem.
Mar 23, 2011 | LG GSA-E60L 20x DVD?±RW USB 2.0 External...
My laptop will not see the external dvd drive. It has power can hear the disc spinning and everything, but windows will not recognize that i have it plugged in
If you get any cd with your driver,please install it. still problem do the following method
1.control panel->system->hardware->DEVICE MANAGER 2.uninstall your driver 3.restart you computer 4.on tray icon a balloon come with a MSG of 'found new hardware' 5.click on it 6.select your driver from it .then select suitable option
if you still have problem buy a you op(win xp,vista,7..).using that disk repair you computer.
Feb 26, 2011 | 8x8 DVR-XD08 8x DVD RW Slim Drive - -...
Will not play blue ray disc
Hi
All u need to do is to visit the manufacturer website,you will see a link "download driver upgrade". Download this upgrade and store it in a flash (if your player has a usb port) or just burn it on an empty CD.
Insert the CD or flash drive into your player,the system recognizes the upgrade and automatically installs it..and you are good to go
Good luck
Apr 23, 2010 | Sharp AQUOS Blu-ray Disc Player
I intalled model iHAS324-32 Y to replace iHDS 11807-4 and vista wont run with it. Tells me to uninstall it and contact manufacturer. I uninstalled it and system works fine again without the disc drive.
Is your vista a 64 bit OS? If so this dvd-writer is compatible with 32 bit OS. You may need to upgrade the firmware for it. Maybe this link can help LiteOn firmware search.
I've upgraded firmware for a dvd writer already with no bad consequences but I have crashed one of my motherboards trying to do the same. So if you're not comfortable doing it, get the people you bought it from or some techie to do it for you. Hope this helps
Dec 22, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Drive no longer recognized by system. Have to open manually and does not read any disks.
It might be either a driver problem or your disk drive dying. Try going to the Fantom website to get and install new driver. Be sure to back up the old drivers first when asked! If this does not work, then your drive might have worn out and you may need to buy a new one.
Dec 05, 2009 | Fantom Drives USB 2.0 DVD-RAM Burner
Can't read dvd ram disk
Well not all DVD Rom's are compatible for DVD Ram. Other problem would be the formatting. Windows XP Home and Professional can only write directly to FAT32-formatted DVD-RAM discs. For UDF-formatted discs, which are considered faster, compatible device drivers or software such as InCD or DLA are required. Windows Vista can natively access and write to both FAT32 and UDF-formatted DVD-RAM discs, however Windows Vista uses its own version of the UDF format giving compatibility problems. Vista also has issues with XP formatted FAT32 discs as Vista uses the CPRM features. Even though it is possible to use any file system one likes, only very few perform well on DVD-RAM. This is because some file systems frequently over-write data on the disc and the table of contents is contained at the start of the disc.
Jan 31, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
VDR M50 drivers for Windows Vista Ultimate
plug the camera in via usb so the camera shows up as a removeable drive. if it picks up the camera as a DVD burner instead of drive, install the DVD-RAM drivers (in compatibility mode for XP SP2 w/ administrative privileges if necessary) and browse the contents of the disc - copy and paste the VRO file to your hard drive and rename it as an mpg - should be readable at that point. good luck.
Mar 03, 2008 | Panasonic Palmcorder VDR-M50 DVD Camcorder
DDVDRW8DB
It may be how you are burning these discs, if you burn it as a data disc you will only be able to read them with a computer dvd drive, if burnt as video it should work on any dvd drive.
Feb 02, 2008 | Digital Research (DDVDRW8DB) DVD±RW...
ASUS DVD RW model DRW-1814BL
try reinstalling your operating system ( try format your cd or just repair it). The system will automatically detect the driver for your drive but if it was not listed in the bios try checking the cables attached to your drive.. or still if not.. the drive may be damaged.
Jan 22, 2008 | ASUS (90-N801W1000) DVD-RAM/DVD-RW Burner
Computers & Internet Logo
David Payne
David Payne
