Question about Lexmark JetPrinter X1185 All-In-One InkJet
I have a lexmark x1185 all in one printer and when I open the top to replace the cartridges they do not move to the center??? Any help???
    Problem Solver:
  • 14 Answers
First of all, I would suggest you to disconnect the power supply from the back of the printer and reconnect it after 60 secs. Once you are done with this, try turning on the printer. If the carts doesn't come to the middle, then there should be something wrong with the printer hardware. Do you see any lights flashing on the printer? If you are hearing a slamming noise when powering on the printer, that is an indication that the encoder strip (the strip which holds the cartridge in position) is off! This needs to be fixed by a hardware specialist. Incase if the printer is under warranty, you could ask for a repalcement.
Merry Christmas!
Posted on Dec 20, 2008
I ddon't know how to get the printer to recognize the color ink that I have installed. The printer will not print.
Make sure you are inserting the correct cartridge for your model. Try to clean the print cartridge nozzles using the computer. Load plain paper. Open the Lexmark Solution Center (go to Start, Programs, Lexmark 1100 Series, Lexmark Solution Center). From the Maintenance tab, click Clean to fix horizontal streaks. Click Print. A nozzle page prints, forcing ink through to clean the clogged nozzles. Try to print your file again and check it's properly printing now.
May 04, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Start buton is blinking
Open the printer cover and check if the carrier is moving to the center. (Mine didn't)
The power light is blinking because the printer carrier is not moving.
Open the printer cover again, if it won't move to the center, pull the white cable that you will see there. Please be very careful in doing so.
After moving the carrier to the center, take the cartridges out.
Close the cover again and open it. Check if it will move.
If in case the carrier did not move to the center, unplug the black box behind the printer.
Turn the printerupside down (I kid you not).
Shake the printer for 10-20 seconds. (still not kidding)
Check if you will see any foreign objects falling from the paper feed path. (nothing fell out of mine)
After that step, plug up the printer again and check if the carrier will move to the center. (Mine did)
Put the cartridges back in and print.
Jan 17, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Hi need to know how to open my printer and get to where i need to put the new cartridges in it i have a lexmark x1185 please help me
The entire top of your printer lifts up. (Scanner unit.)
Refer to this setup guide:
Lexmark X1100 Series Setup Guide
See steps 6 through 9.
Once the lid is lifted, there are locking tabs on each cartridge. Squeeze and lift up. You can then lift up and out on the cartridges. Reverse the procedure to install the new cartridges.
NOTE: Make sure the printer is ON during cartridge removal and replacement.
Thanks for using Fixya.
Nov 05, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Open cover problem
Dear sir,
this problem is your all in printer scanner door swich is open active printer when you change cartridge then open your printer scaner top and change your cartridge replace work finished then you inser home position there is a switch is liver was broken or displace so open cover problem
Jul 31, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
My ink cartridges won't move to the center when I open the printe
Be sure the printer is powered on as it needs power to move the cartridges - this is a common mistake.
Dec 18, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
I cant figure out how to change the ink cartridges on my lexmark
On an X4850 the whole top of the printer opens up to reveal the cartridge carriers. Press down on the latch of each side to reveal the cartridges.
Here is a link to the User guide: X4850 User Guide It is described on page 94.
Nov 19, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185
If the ink cartridge is not empty it is probably clogged. The Print nozzles are very sensitive and cleaning attempts can make the situation even worse if carried out wrong. You can try cleaning with dry gas alcohol as it contains no water. Use a piece of leather sham or other non lint material like eyeglass lens cleaner wipes and the dry gas. Wet your cloth and gently hold it on the print nozzles allowing the alcohol to dissolve the dried ink in the nozzles. Do not rub hard or you will ruin the print head. Hold it in place for at least 2 minutes with a generous amount of alcohol in the cloth. Imm
ediately place the cartridge in the printer and perfom the clean nozzle function.
If this does not remedy your problem the print cartridge must be replaced. Hope this helps you out.
George
Jun 10, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark All in one printer
looks like you may need to replace the black cartridge.
usually when you open the cover of your printer, cartridge carrier will move to the center. that's where the cartridges are, you can open it buy pushing it down and release it.
you can also checked lexmark site for this
check out this link too.
x1185 and x1100 are most likely the same.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Mar 26, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
