Question about Samsung CLP 300 Laser Printer
Status light stays red,
The status light was red and the yellow ink light was on. So I put in a new yellow ink cartridge and now the status light is on and the yellow ink light is off.
    President:
  • 1,257 Answers
See the manual on how to reset it...
Posted on Dec 18, 2008
  • Samsung Master
  • 19,396 Answers
Remove the cartridge, unplug the power, power it back and put in the cartridge, this is powercycling, let me know it it works
Scx 3200 samsung status light
If you refiil the toner cartridge ,now must be change the cartridge chip.The chip countered the total copy,not how many time you refill the toner.The original chip working 1500 copies,change one new chip to 1,5K or 3 k or moreK(K=1000 copies).
Mar 26, 2013 | Samsung CLP 300 Laser Printer
How to find ink levels in hp932c printer
Print Cartridge Status The Print Cartridge Status Light flashes when one or both of your print cartridges are low on ink, improperly installed, or malfunctioning. It will also flash if you are trying to use the wrong print cartridge type. If the problem is low ink, the light will stop flashing when you open the top cover. For any other print cartridge-related problem, the Print Cartridge Status Light will continue to flash. To check the status of your print cartridges, open the printer's top cover. The yellow arrow on the print cartridge cradle aligns with one of five Print Cartridge Status icons.
Jan 08, 2011 | HP DeskJet 932c InkJet Printer
HP Business Ink jet 1200. Yellow cartridge lite is on. Changed cartridge, but lite is still on,
Ink cartridge lights: Black, Blue, Magenta, Yellow
When light is on - ink is low (below 25%)
When light is flashing - out of ink - printer stops - replace cartridge
To get a printer status / configuration report press the info button (to the left of the on button)
Oct 07, 2010 | HP Inkjet 1200dn Printer
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Toner light and Status light stays on
well it may need to be completely reset or you could try seeing if it is jammed or stuck in some way
Sep 11, 2009 | Brother HL-5240 Laser Printer
Changing color cartridge on my epson stylus color 980 printer.
If you need to replace an ink cartridge in your printer, please follow the instructions below:
To confirm which ink cartridge requires replacement, please use the printer's control panel (there is a black ink out indicator, as well as a color ink out indicator ), or the Status Monitor in your computer.
Red light flashing - Low ink
Red light solid - Out of ink
1. Open the printer cover and press the INK (Cleaning) button for 3 seconds. The print head moves to the center and the lights flash.
2. Lift up the ink cartridge clamp. The cartridge rises up from its holder.
3. Remove the cartridge and dispose of it carefully. If ink gets on your hands, wash them with soap and water. If ink gets in your eyes, flush them immediately with water.
4. Unpack the new ink cartridge and remove the yellow tape. You must remove the yellow tape from the top of the cartridge. Do not remove the clear seal underneath the cartridge. Do not touch the green circuit board on the back of the cartridge, or you may inhibit normal operation and printing.
5. Tilt the new cartridge toward you slightly as you insert it. Lower the cartridge so that the tabs rest on the hooks. Do not place the cartridge tabs under the hooks.
6. Press down firmly on the ink cartridge clamp until it snaps in place.
7. If you need to replace the other ink cartridge, repeat steps 2 through 6 before continuing with step 8 (to move printhead over to color (if black was replaced first) press the cleaning button once).
8. Press the INK (Cleaning) button once, and close the printer cover. The printer begins charging the ink delivery system.
9. Wait until ink charging is finished (the power light stops flashing and the red error light goes out).
May 11, 2009 | Office Equipment & Supplies
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Red Light won't go out!
ok can u tell me what status monitor says?
Aug 09, 2006 | Epson Stylus C84 InkJet Printer
Samsung CLP 300 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
