Question about Air King Granada GRAN30SS Stainless Steel Kitchen Hood
Yesterday i was cooking i had 4 burners on and my range hood on low. All of the sudden, the fan/motor just stopped working. I thought it overheated and would need time to cool off and would work again. But a day later, the fan/motor is still not working. The light button works and they turn on and off, but none of the fan speeds are working. It just makes a little click sound when i press the fan buttton. Any ideas? I checked the instruction manual and there is no troubleshooting for this particular model. I had the hood a little over a year and haven't had a problem up until now. It isn't covered under warranty anymore i dont' think. Thanks!
Often these motors have a condensor on the side - a bit like a cross between the little white cylinder in a flourescent light housing and a starter motor - they are a bit vulnerable but are pretty cheap and easy to replace. Sounds like that is the problem - little click is it trying to start but not getting the extra help from the condensor. any good electrician should be able to fix it quickly, unless a part needs to be ordered in. he should also check if there is a fuse inside, and if the main part of the motor is ok. If the motor has died completely (which is rare) then it is still probably worth replacing, but might be a but costly. also there could be a relay connected to the switch (a way for a small switch to transfer heavier current to something) - and sometimes these can also fail. Also easy for an electrician to check and fairly cheap to replace. some motors also have a thermal protection device, which may be able to be reset by pressing a small button on the side somewhere, also possibly faulty and cheap and easy to check/replace. if you can look at the motor easily, just see if there is a small plastic push button switch (almost certainly connected to the body of the motor somewhere) if so, make sure the power is off, push it in and it should click to an "in" position. Might solve the problem. If you get a guy in to look at it and he is struggling to find the parts, please post again and we can try and source them online for you. If you fancy trying it yourself then post again and we can try and talk you through it, not TOO hard but you would need a bit of electrical knowledge and tools. Hope this helps :)
Posted on Mar 29, 2007
Jan 25, 2016 | Creda Kitchen Ranges
Jun 14, 2014 | KitchenAid 36 in. Wall Canopy Range Hood
Dec 11, 2013 | Thermador CVS236 36" Cook 'n' Vent System...
Oct 21, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Nov 14, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Oct 04, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Mar 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Apr 23, 2018 | Viking Kitchen Ranges
602 people viewed this question
