Question about InFocus IN26 Multimedia Projector
Infocus in26 fan runs continually
After power down, the fan runs until the light is solid which indicates the bulb is cool. However the fan never stops. Continuous humming.
    Scholar:
  • 167 Answers
The fan does run continuously on this projector however it should be running very very slow when the projector has completed it's lamp cool down routine.
The reason for this is that a portion of the switching power supply remains energized (running) when the projector is at rest. But as I mentioned it should run very slow in this state. If it remains running full blast then most likely the fan speed control chip is shorted which can cause fail 2 ways, either the fan 1. runs full
speed or 2. remains stalled (then the projector will go over-temp and shut itself down) I hope this answers you question.
Cheers
Posted on Dec 30, 2009
Projector will shut off after 15 min of use and won't restart till cool down fan is on and running
If this is one of the first IN26's made, this could be a lamp issue. Take the lamp out and look at the side that is closest to the underside of the of the top cover when installed. There should be foil tape covering the seams on the lamp. If not then heat is escaping from the seams and causing the thermal sensor to shut the projector down prematurely. This can be fixed by applying foil tape over the seams. If the lamp is already taped, then it could be a problem with the main board and will have to be fixed by a technician.
Dec 06, 2010 | InFocus IN26 Multimedia Projector
How do I replace the ballast in an InFocus IN26? And while we're at it, where do I get one? I've already replaced the bulb with a new one (direct from InFocus), reset everything to factory settings, and...
remove the front and rear bezels, remove the top cover, take a picture of the location of screws and ground wire on the metal frame. remove the top boards, remove the metal frame and there is the ballast/power supply. pay attention to the way the cable is routed to the lamp connection, also pay attention to which way the connection from the ballast is seated in the lamp housing. hopefully a new ballast will fix it for you, as to where to get one, that's iffy. you could try to find an in26 on ebay that has other problems but has a working ballast
May 11, 2010 | InFocus IN26 Multimedia Projector
Power in cable, but projector is dead - no light, no fan.
bad power supply. you can get the part from an infocus service center, or send it to them to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 08, 2010 | InFocus IN26 Multimedia Projector
InFocus IN26 overheating
clean it out. use canned air and blow the dust out of it. sometimes after many overheating issues, the temperature sensor needs to be replaced. but first clean it out and make sure the fans work well. if they spin slowly, replace them.
Oct 03, 2009 | InFocus IN26 Multimedia Projector
The bulb on X1 blew out, I replaced the bulb, the
it's the fan. if it won't spin full power, it can't cool down the projector and it'll shut down. there are 2: 60mm (part # 526-0153-00) and 80mm (526-0152-00). both can be purchased from infocus or an infocus service center.
Aug 10, 2009 | InFocus X1 Multimedia Projector
Infocus X1a LONG startup times
Sounds like the power supply is weak if it has to run for awhile before it functions. The control board could also be the issue. Does it make any grinding or buzzing noises?
Jul 18, 2009 | InFocus Televison & Video
Infocus IN26 Projector
Yes the problem is due to over heating.It would be perfectly acceptable to have inlet air to the projector that ranges between 70 ? 76 Farenheit. Most projectors are designed to operate with inlet temperatures well above this value, usually up to about 90F.Set your air-conditioner to the value specified and it should work fine..
Oct 09, 2007 | InFocus IN26 Multimedia Projector
InFocus IN26 Multimedia Projector Logo
202 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
