Question about Porcher 5535-254.___ Reprise Pillar Taps Bath Faucets w/Cross Handles
Bathtub water won't shut off
My cold water tap will not shut off in the bathtub. I have just re done the copper pipes as the pipes in the bathroom burst. They are the old type where the taps are seperate from the spout and about 3 inches higher. Any ideas on how to fix this?
  • dinkykutti Feb 07, 2009
    bathtub water won't shut off--jsut bought an old house and opened the tap water to clean the tub and now it wont shut off, also the spout was loose--help please
Did you solder close to the valve. you may have melted or damaged you cartrage inside. shut water off and replace it.
Posted on Dec 19, 2008
My Royal bath tub leaves residue each time I use it. How can I stop this
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Oct 18, 2013 | Whirlpool 5"x36" White Bathroom Drop-in ...
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
Rusty water comes out of cold water faucet
Rust is usually a sign of galvanized pipe mixed with copper pipe incorrectly.Could be the pipe nipple used for the tub spout connection to the valve.You could change it to a brass nipple might be the problem
Jun 24, 2010 | Moen 1 Handle Lever Shower Faucet With...
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor...
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
Feb 23, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
American Standard bathtub tap noise
possible that the pipe's are not,secured properly in wall. and you did not say what kind of faucet you have, but if it has washer's,the screw's that hold them, may be loose.
Feb 19, 2010 | Home
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Porcher 5535-254.___ Reprise Pillar Taps Bath Faucets w/Cross Handles Logo
647 people viewed this question
Top Porcher Plumbing Experts
Paul Carew
Tom Chichester
Are you a Porcher Plumbing Expert? Answer questions, earn points and help others
