Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
KUDS01flbl3 stopped in mid cycle, full of water, no lights on control panel. I verified there is power to the the dishwasher. I have the unit out from under the counter and the door cover is off. Where do I go from here?
4 Suggested Answers
  • 5911 Answers
SOURCE: kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Posted on Aug 15, 2007
SOURCE: KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Posted on Sep 22, 2007
  • 43501 Answers
SOURCE: The dishwasher is leaking at the bottom of the
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Posted on Sep 29, 2010
No lights on control panel
sounds like a power issue or bad control board
Feb 06, 2015 | Washing Machines
Kenmore elite dishwasher stops mid cycle
I assume you mean it stopped in mid cycle and is now dead. If this is the case you will need to turn off the power to the dishwasher and remove the screws holding the front control panel There is a thermal fuse clipped to the front of the control panel Check it using an ohmmeter or continuity tester If it is open you will need to replace it with a kit containing the fuse and wire connectors Do not replace just the thermal fuse the problem will surely return. Also inspect the control board for burned areas.If the control board is burned you should replace the wiring harness with the control assembly
Jan 25, 2014 | Kenmore 24" Built-In Dishwasher with...
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Unit is dead: does not appear to have power
Hello chicagogunn,
You said,Your unit stopped working mid-cycle. You have verified that there is power to unit. Is there an internal fuse which could have been tripped? None of the lights on the control panel currently light.
There is a thermal fuse!
Go to this repair web site I listed below and you will see the diagram
1. Diagram Page 02 - CONTROL PANEL PARTS
2. The thermal fuse is, Item # 6 on the diagram.
3. Click on page two on the left at this site.
4. And then in the upper right corner it says Open This Diagram in a New Window
6 8193762 Fuse, Thermal Electronic In-Stock $ 13.25
Let me know how you do!!
Please remember to leave a rating!!!!
Here are four things that the repair manual says to check.
Burnt or broken wires
Check for burnt or broken wires. This would include the wires on the timer and door switch. Also check the wiring connection where the main power connects to the machine.
2. Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a volt /ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician
3.Door switch
The door switch is wired in series with all components on the machine. If the door switch is defective, the machine will do nothing. Check the door switch for continuity
4.No Electrical power
Ensure that the proper voltage is being supplied to the appliance. Check the breakers or fuses that are supplying the power to the appliance electrical outlet. You can use a voltmeter to test for voltage at the electrical outlet.
Thank you Huuum
Oct 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Kenmore Model 16253 - Stops mid cycle
Sounds to me that the heater is not working, if you have just bought it, it must still be under Guarantee so go back to the supplier.
Nov 18, 2007 | Kenmore 16253 Stainless Steel Dishwasher
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
52 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
