Question about Canon PowerShot SD600 Digital Camera
My lens wont fully extend
Alright, so when I turn on the camera to do business. The lens pops in and out as it should, but then my camera beeps a few times and says "lens error, restart camera" Now I restarted the camera 7 or 8 times and I keep getting the error. I have a feeling its the camera's lens track not allowing the lens to fully extend during the operations check. Any input?
  • 2 more comments
  • enyce360 Dec 17, 2007
    my camera states lens error, restart camera how do I restart it
  • tracy carlin Apr 27, 2008
    When i try to turn on the camera, it does not turn on and on the LCD displays lens error
  • Anonymous Jun 01, 2008
    Same thing on my SD600. It was fixed once by Canon ($80) who claimed the lens mechanism was "dented" It's happened again. It's not dented and there is no foreign matter
  • Anonymous Jun 03, 2008
    when i try 2 turn it on it makes a noise and says lens error please restart
    wat can i do to fix it??
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Posted on Jul 01, 2008
Please take a look at the fix, this has worked for me and it only took maybe 10 minutes. It was a life saver, we bought a second sd600 at a garage sale for $5 dollars including battery and charger. We figured it would be good just for the extra battery. Then we found this link to fix our lens error message, and what do you know sand was inside and stopped the gears from moving. We took a sewing neddle and blew inside and cleaned the case too. Please do this before sending into cannon.
http://www.williamclayton.com/entries/fixing-canon-powershot-sd600-lens-error/
Posted on Oct 24, 2009
If your lcd shows E18 this might be the dreaded Canon E18 error. Google Canon E18 for more info.
Posted on Mar 29, 2007
Camera wont turn on and lens wont go in and i just put new batteries in
Lens of the Camera doesn't retract:
Before trying any of the suggestions, make sure that the Battery is
fully charged and in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed
air (20 lbs) set the tip between the lens turret and the camera body
and turn on the air while moving the tip around the lens. It should
remove all dust and sand. Turn the camera on and it should function
fine.s
3) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and
take a look at the spacing between the lens and the lens housing. If
you notice that the gap is not even all the way around the lens, the
problem should be easy to fix. This type of a problem usually occurs if
the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try
powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts
again, do the following.
(a) Turn the camera off.
(b) Take the camera in one hand and with the other gently take one part
of the lens and gently move it round in a circular movement. Do so with
both sections of the lens. You will hear a "click" as it pops back in
place.
(c) Power the camera on.
Another version of this fix would be to pull and twist on the largest
ring of the lens while turning the camera on. Listen for a "click". If
at first the focus seems to be off, turn the camera on and off and take
lots of pictures, close ups and distance. Focus should slowly start
improving.
Dec 02, 2009 | Kodak EasyShare C913 Digital Camera
Camera turns on but lens dosnt extend fully
your camera lens may be stuck in the barrel.
Apr 11, 2009 | Cameras
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Casio EXILIM camera lens will not extend fully!!!
Try plugging the PC interface cord into the external connector. No need to hook it up to your computer, just plug it in and out a few times. Then try to power up the camera.
Good luck.
Zductive
Jun 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Beeps 3 times
Is it an actual beep, or is it a beeping noise coming from the lens? Does the lens extend? I ask this because this is the noise the lens focus gears make when they are knocked out of alignment, or debris gets in them and jams them.
Jan 11, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Turn camera on and it beeps twice then shuts off after 5 seconds
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black casing and see 2 PLASTIC GEARS. One is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Apr 11, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera no screen display
I wish this guy with the twist it blow it and bash it would take his advice eleswhere. He reckons it's the cure all for every digital camera with an extending lens. I've had a couple of the RR10s exhibit no life except a few flashes of an LED. The simple fix was to firmly squeeze the lower half of the camera's front and rear together. What happens is that either over time or if subjected to a slight shock the two main circuit boards part company at a rather large multipin plug and socket. Squeezing the front and rear (just above the hump at the bottom front of the camera)makes this plug and socket return to where they should be. The first one took me about 2 hours trying to figure out but the second took me about 4 seconds to get working again. WARNING don't overdo the squeeze be firm but not aggressive. I use both thumbs on the front and fingers on the back but stay clear of the LCD.
May 08, 2006 | Casio Exilim EX-Z4U Digital Camera
Canon PowerShot SD600 Digital Camera Logo
1,371 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
