Question about Cuisinart 12 Cup Digital Thermal Coffee Maker - BLACK
Thermal carafe has liquid in cavity and coffee does not stay hot
It seems as though water ? has got inside the cavity walls of my Cuisinart DTC 975N thermal carafe, not sure how but the pot is extremely heavy and you can hear the liquid sloshing around. I still tried to make coffee but it tastes very weird and the pot does not keep the coffee hot anymore. I cannot see how to open the pot to let the liquid out and clean it. It has been a finicky coffee maker since I bought it last Christmas - it sends coffee all over the counter randomly even after triple checking the basket is in place & descaling with vinegar on regular basis, however It cost a lot of money & I dont just want to throw it. Can it be fixed?
  • 8,596 Answers
Call Cuisinart and see if they consider it an in-warranty issue (it has a 3-year warranty). If it were just the liquid issue that would be one thing, but since it's not keeping the coffee hot, then you have a hidden crack somewhere. Mine has the sloshy liquid issue, but I just live with it since it still keeps the heat inside. Otherwise, it's been a great coffeemaker that has lasted for over 6 years. As far as the coffee spilling everywhere - I would switch to paper filters (don't use the paper in conjunction with the gold tone filter). The filter basket door latch may be worn - as many problems as you're having, this may be a warranty issue that Cuisinart can solve.
Posted on Mar 31, 2009
Our brand new Cuisinart model DCC-1150 10 cup coffee maker with the stainless steel thermal carafe makes a great tasting cup of coffee but the coffee isn't piping hot when first made and the carafe doesn't...
I am having the same problem, along with the coffee leaking onto the counter. I think this coffee pot is just defective. If not, I wish someone would come up with an answer.
Oct 21, 2010 | Cuisinart (DCC1150) 10Cup Coffee Maker
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There...
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Jul 29, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee leaks all over the counter every time coffee is made. coffee appears to be coming out of bottom of machine Coffee pot lid is on correctly.
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
Jul 29, 2009 | Cuisinart DCC-1200 Coffee Maker
My cuisinart DCC-2000 will not urn on I have only had it for 2yrs what can I do to fix this?
i've had mine 2 years also, Many times it would not brew. If cleaning it with viniger water doesnt work your supposed to unplug it for an hour to re-boot the system, which defeats the point of having a good cup of joe before work.  i clean it regularly with the vinigar water, something i've never had to do that often (if at all) with any coffee maker before.  So in my on-line researching i discovered they have a decent customer service. i called and they are replacing it for free, no shipping charges for my state. the model 2000 we have happened to be on backorder at the time so i selected the DTC-975BKN with the stainless steel thermal carafe. It seems most all bloggers were very happy with this model. no drip problems. no program problems. and the coffee stays hot in the thermal carafe for hours without getting burnt from a hot plate - the reason i originally chose the 2000 model. so my suggestion is to call customer service and have yours replaced with the same one or one you like better. warranty is 3 years. the number is 1800.726.0190
May 03, 2009 | Cuisinart DCC-2000
Filet folded & overflowed. Now coffee maker will not make coffee
Clean your coffee maker with vinegar or as the manual instructs no fewer than 3 times per year, at least 3 times back-to-back if you haven't been doing so regularly. The heating element may be overheating due to hard water deposits, triggering the end-of-cycle shut off.
Apr 12, 2009 | Cuisinart Coffeemakers
Inside of the carafe
The only thing that work well for me was Dishwasher liquid. put a litle in the pot with some real hot water, put the lid on and swirl for a minute, being careful not to spill. Then place in the maker filled with just enough water to fill the pot the rest of the way. Then shake and swirl over the sink, being very careful not to get that very hot water on you. You may have to do this twice. You will be surprized with all the junk that come out. Then rinse it a lot. Then I place vinegar and baking soda in the bottom and run it through the cycle twice . Very clean and fresh and the coffee tastes great. A lot of work though.
Apr 06, 2009 | Cuisinart DTC-975 Coffee Maker
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Thermal carafe clogged
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Jan 03, 2009 | Cuisinart Thermal DGB-600 Grinder
My thermal coffee carafe is coffee stained. How do I clean it?
I have had success with putting a small amount of liquid dishwasher soap in the carafe. Then, I fill it with water. I let it set for a few hours. Then, I rinse the carafe out and follow up with a regular washing - cloth and warm water. It is sparkling when I am done. I find that I don't have to do this often.
Jul 06, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart 12 Cup Digital Thermal Coffee Maker - BLACK Logo
263 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
