Panasonic rear projection
Hi there
I've Panasonic TV TX51P100H with convergence problem, A group of tech try to fix this TV because in service mode lines are bent to inside (up and bottom, left and right) and line data didn't moves with cursor.We replaced both STK IC two time.
Finally we decided to replace convergence board and processor but now its not available.
your advise is very valuable for us.
If you know where do we get spare or any another solution for this fault.
Regard
Som.
    Top Expert:
  • Televison & ... Master
  • 75,871 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Convergence procedure to many brand projection TVs are given.
Posted on May 08, 2017
premtech
  • 934 Answers
SOURCE: convergence problem
That unit has a convergence repair kit that should fix most problems. Order it directly from Hitachi p/n# X480295. It contains: Rk42 3.3 Ohm 1w Rk46 1.8 Ohm 1w Rk50 3.3 Ohm 1w Rk54 1.8 Ohm 1w Rk58 3.9 Ohm 1w Rk62 2.2 Ohm 1w Ik04 Stk392-150 Ik05 Stk392-150 And I would strongly recommend testing all the resistors in that circuit for change in value. Are you using a good heat sink compound on the STK's when you installed them? That and ordering the japanese knock-offs for STK's are the two most common critical mistakes made. Originally that unit had two STK392-110's for conv. amps. Even Hitachi recommends subbing to a STK392-150 or 180 for greater reliability. You do realize that for the cost you have after two failed attempts you probably could have taken this to a reputable shop and watching the ball games now. :) (no disrespect intended) Good Luck! Bill
Posted on Jun 01, 2007
SOURCE: CONVERGENCE ic CHIP
I replaced the Convergence IC Chip STK392-110 for my PT-53WX42 Panasonic HD Rear Projection TV but I found burnt resistor(resistor #)R7053,R7002 & R7005.Can someone tell me the part# ,description,resistor value and power rating.I don't have the schematic to look .Thanks
Posted on Sep 08, 2007
  • 3 Answers
SOURCE: Zenith r57w46 red gun
Help its convergences is off...call back or what?
Posted on Nov 08, 2007
SOURCE: STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Posted on Mar 11, 2009
maatmartin7
  • 1241 Answers
SOURCE: convergence prob on toshiba mod 57h82...is stk
No. If you already tried, you already know why. Repair on TVs require the exact parts. If you feel you can repair this, the suggestion is see the website,www.TvRepairKits.com. Here they can instruct very throughly. You will find photos to see what you will be working on. I have repaired several TVs using this web. Be sure you have the model number and the symptoms you describe. If you have any further questions concerning repair, ask me here. Thanks for asking and show a few hands of support.
Posted on Mar 10, 2011
How do I fix the convergance on a sony 57" rear projection tv. Just started to look 3D the other day when turned on.flash focus does not help.
Get an ESR capicitor meter and check for dry or blown caps on the convergence board - replace the 2 convergence ICs (but ONLY do this if you are electronics qualified - or get a tech to do it). Clean the lenses of the tubes - these come completely apart and you can change the fluid too - usually this is a $250 per tube job (there are 3 tubes) for a tech but you can do this and replace the fluid yourself which will clean up the fuzzyness. Then reconverge and do the flash focus for all zooms (you may have to do this several times).
Here is a link too for the service manual which details how to converge your set - http://tv.groups.yahoo.com/group/Ws500/
Jul 07, 2010 | Sony KP-51WS500 51" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Tv is showing double vision with red being the second image
This is due to convergence out chips failure, replace convergence out ICs in TV to get converge picture.
If you are handy with electronics stuff repair and want to repair TV by yourself (soldering work is required) then let me know exact model number written at back of TV to provide you more technical info OR ask local tech to fix it.
Thanks.
Jan 07, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Picture looks almost 3-D
When convergence out ICs stop working in rear projection TV, picture looks 3D affects.
Need to test/ check supplied volts on convergence out ICs on main board and if volts are OK, replace both ICs.
I'm not sure if you are going to repair TV by yourself or will ask local tv tech to fix it. Let me know please.
Thanks.
Sep 14, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic tx51p100h shows horizontal blue then shuts off
la fuente de alimentaciom y vulve a revisar minuciosamente le convergencia poedes tener una resistencia elterada o abierta
Aug 26, 2009 | JVC AV-56WP74 56" Rear Projection...
My tv is over lapping colors on the words
Convergence needs to be aligned try in mune under setup, if will not aglin the its bad convergence IC's, need tech
Aug 09, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projection tv
HI, The Pc Board that is located in your set, has become unstable. there are several IC's that control convergence and input streams as well. the damaged board should be replaced asap. it is possible for a service tech to be directed to your home but, most will require you to transport your set to the actual repair shop. i will list the part Number below.
Panasonic Part Number: TNPH0370ADS(PC BOARD) $347.95
Jun 19, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Rear Projection PT-47WX42CF42
Make sure your yoke plugs are clean and no cold solder joints around them. Let me know? Do you have a scope?
Apr 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Power comes on then goes back off.
More than likely, the two convergence IC's have to be replaced.
Jan 28, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
