Question about Whirlpool GS470LEM Gas Kitchen Range
WP Touchpad does not work.
Whirlpool GS475LEMS1 gas range displayed error E1 F2. Replaced entire control (and keypad) with new part and display still shows error E1 F2. What else has failed?
  • dhteichman Dec 19, 2008
    I replaced ERC assy (touchpad AND board) with new part. Still displays the same error (E1 F2). I interchanged touchpads and boards (between original and replacement parts) and still get same error (E1 F2). I don't think it's in the touchpad or ERC or ERC Assy. Any other failures that could drive these codes? I'm already into this for $300. The technican I called wanted $600. Upon power-up the display shows "PF" then soon displays "E1 F2", then beeps once every few minutes. None of the keys respond.
  • Anonymous Mar 14, 2014
    What is error f2,
  • 8,197 Answers
The error code of F2 and E1 on your gas range is indicating a keypad failure or an Electronic Range Control (ERC) board failure. The ribbon connector on the keypad could be damaged or shorted. One of the buttons could be stuck or shorted on the keypad. There is a good possibility of a failed (ERC) board as well.
I recommend having a service technician come out and diagnose which part failed and repair your range.
Posted on Dec 18, 2008
  • Jyackle5
    Jyackle5 Dec 19, 2008
    The only other problem would be the touchpad ribbon. One of the wires could be damaged.
    Good Luck
  • evansx Oct 27, 2010
    you don't need a "professional" to solve this problem or even to order any parts. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem will vanish. if the error ever returns, try pulling out the connector, cleaning the contacts with a pencil eraser (see -http://www.fixyourboard.com/techzone/ove... - for illustration), reinserting it into the slot and repeat above with the paper. good luck.
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
What does the code E1F2 mean on our kitchen range display
This Kenmore was built by Whirlpool. The F2-E1 error indicates a problem with the keypad wiring. Try pressing Cancel. Next make sure that the keypad is connected to the wiring harness (if it is separate from the rest of the control). You may need to replace the keypad or the entire control board (ERC or Clock).
I hope this helps.
Nov 21, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
F2:E1 ERROR CODE
Hello Cjarboe,
I understand that your range is given you F2:E1 code this code states that the keypad cord is unpluged. If you find that it is plug in and the error code comes up again you will need to replace the keypad. Here are the dirrections to check/replace the keypad.
1. Unplug, shutoff power to the unit
2. Remove the knobs from the top of the control panel
3. Remove the endcaps
4. Unscrew the control panel
5. Locate the serial cable comming out of the keypad do the jiggle and make sure wire is tight on the keypad and control board.
6. Reassable in the revearse
7. Check to see if error code displays again if it does you will need to replace the keypad.
This range has been discontunuied by whirlpool and parts are hard to come by. Here is a link that I have found the keypad for $243.42 at the followign link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=254959&diagram_id=28176301#d28176301
Thank you for choosing FIxYa.com
Justin
Mar 30, 2011 | KitchenAid KGRT607HBS Gas Kitchen Range
Whirlpool double oven rbd306pdb15 displaying code e6 f2. What does this mean?
HI. This code is in reference to the keys that initiate actions on your unit, The cancel key is malfunctioning at this time. Follow the procedure below to correct the issue.
1. Disassemble the control panel and check the keypad connector for firm connection (keypad connects to the control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Aug 23, 2010 | Whirlpool Ovens
The range displays f5 e1 when i try to run cleaning cycle
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&*(
May 12, 2010 | Whirlpool GS460 Gas Kitchen Range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#$%
Mar 20, 2010 | Whirlpool GS460 Gas Kitchen Range
E1 -F5- .. Locked - displays after cleaning the
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Dec 21, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool accu bake oven door locked after self cleaning
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^YRG
Apr 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
E1 F5 displays cannot use the oven whirlpool gold range When I triy to bake it doesnt let me it beeps twice an didsplay E1 F5, I pushed all cancel button on the range to no avail
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Feb 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Whirlpool GS470LEM Gas Kitchen Range Logo
1,414 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
