Question about HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop
I have a deskjet 840c.i conect with my xp comp with usb cord but it is not runing.give some tips to start printer.
  • 115 Answers
Before connecting the printer put the cd that came with the printer into cd/dvd drive. This is to install drivers for your printer. Follow the instructions that comes on the screen. If nothing comes on the screen then run setup.exe from the cd.
Connect the printer when asked to do so or only after installing the programe.(i.e. drivers). good luck
Posted on Dec 18, 2008
I have an 12 year old hp printer still going strong hp deskjet 840c. Sometimes it shows a connection error that is the computer doesnot detect the printer I use a usb cable for connection. The printing...
Hi I think your printer has a parallel connector ( big D shaped socket with wire clips each end) on it if your pc also has a parallel plug get a parallel lead and install the drivers to use LPT1 this should remove the faulty USB plug from the problem
good luck Ian
Mar 25, 2011 | HP DeskJet 840c InkJet Printer
My new computer does not have a parallel printer port. My old 840C printer has both parallel and USB ports, though I only ever used it with a parallel cable, so I tried connecting with a USB cable. The...
Hello and welcome draepeacock !
The only solution is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Regards .
Feb 14, 2011 | HP DeskJet 840c InkJet Printer
I cannot install my Deskjet 840c printer to my windows 7
The Deskjet 840c driver is included in the Win7 OS. You need to use Windows Update. Connect the data cable to the computer. Windows 7 should find the driver. If it doesn't, open Windows Update and check for updates. Look under Optional Updates.
If it still doesn't properly install the printer, disconnect the USB cable and then turn the printer off and then on again. Then open the Devices and Printers window and remove the printer (right click and choose Remove device). Remove all icons for the 840c if you have multiple in the control panel. Then reboot the computer and make sure your network connection is active. Reopen the Devices and Printers window and install the printer manually. To do this: click on Add a printer, choose Add a local printer then click Use an existing port. Select LPT1: (Printer Port) in the dropdown menu and click Next. Click on the Windows Update button and wait for the updates to be completed. Choose HP as the manufacturer and the Deskjet 800 series. Now connect the USB cable between the printer and the computer. You should see the installing device driver software window. Wait until the window disappears and then click Cancel on the Add a Printer Window.
If problems persist, try a new data cable. Try directly connecting to the computer if you are using a print server or USB hub. Make sure the computer USB ports are working. The ports can be disabled for security or power savings. (Check in the Device Manager (Start > Control Panel > System and Security > System > Device Manager) or from the advanced settings for the Screen Saver (right click on the desktop anywhere there are no icons or running programs, select Personalize and then click on the Screen Saver icon. then click on Change Power Settings and Change Plan Settings for the active plan).
I hope this helps.
Jan 07, 2011 | Office Equipment & Supplies
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Printer does nt work on laptop
  • Win 98 software version will never support Win XP system. Please download the software for your XP machine via the below link.
DOWNLOAD FULL FEATURE SOFTWARE
  • Save the download the file to your desktop.
  • Uninstall the older version, restart the computer and install the new version from downloaded file.
Thanks & Regards
Rizwan
Jan 31, 2010 | HP DeskJet 840c InkJet Printer
My printer started to only print random numbers and letters MODEL HP DESKJET 840C
Turn the printer off at the wall outlet, reboot your computer and then plug the printer back in.
Nov 17, 2009 | HP DeskJet 840c InkJet Printer
Blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
Dec 18, 2008 | HP DeskJet 840c InkJet Printer
When I try and print a document it is printing in resrse order
try to uninstall the printer and the port say(usb,paralell) then restat yr system n reinstall the printer. try printing from the printer test page if it prints well then yr problem should be from the package ur using may u uninstall n reinstall as well
thanks
May 26, 2008 | HP DeskJet 840c InkJet Printer
HP xw4600 Workstation Linux Installer SATA-SAS PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
