Question about Olevia LT42HVi 42 in. LCD Television
URL of website that might source parts that you recommended.
Jaime, what website did you recommend to me for possible cross reference parts for my Olevia LTHVi 42" LCD?
  • 2,326 Answers
  • Jaime Hernandez Dec 18, 2008
    It looks like ebay has the backlight inverter board if that is the defective part on your TV.
Ngk cross reference chart
I recommend only H-D plugs myself.
Check electrode gap with a wire-type feeler gauge. Bend
the outside of the electrode so that only a slight drag is felt on the
gauge as it passes between the electrodes. The proper
gap measurement is 0.038-0.043 in. (0.97-1.09 mm).
May 07, 2014 | 2001 Harley Davidson FXDXT Dyna Super...
Bottom speakers not working on vs 1520 burning smell has anyone experience this is it the circuitry thats after blowing and can anyone recommend a place to get parts
In my experience, you won't find parts for this anywhere. Behringer has most part numbers custom designed so they can't be found in cross references which means, a technician cannot replace any components accurately with accurate values to accomplish a full repair. I don't recommend any behringer brand equipment to anyone for this reason. The only repair possible here is through Behringer, which is why they did it that way, and also why they price the junk so cheap that you can replace it cheaper than repairing.
Mar 10, 2014 | Behringer EUROLIVE VS1520 High Performance...
How to use original nissan part number to source parts not branded nissan
you can try google search but hours of research to make sure your getting the right part you can go to nissan and try a search of the original part but to get a cross reference you would need to buy a cross reference book
May 28, 2013 | Cars & Trucks
I have a pride 1170xl with E675HT motors. I broke the black plastic brush holder getting the brush out. Can the brush holder be replaced separately or do I need to buy the whole MOTOR END CAP? I may be...
Mark,
The manufacturer parts manual indicates the following information:
The motor brush caps are available from Pride:
PLSINDV1059 Motor brush cap (Reliance 0003-0035) retail $2.68
The brushes are:
DRVBRSH1000 Motor brush Jazzy (Reliance 0002-6957) retail $36.31
The guys in tech service at Pride (800-800-8586) are always a good resource for the information you may need. If you are exceptionally nice to them they will drop a new brush cap in the mail for you for free.
You can also check with Reliance Motors at their website for information and cross reference for other brushes available based on the Reliance part numbers above.
A good local motor rebuild shop can recommend a comparable (more durable) brush based on the specs. I think you may be disappointed with the pricing of the more durable brushes.
You can try on-line at:
http://www.graphitestore.com/items_list.asp/action/prod/prd_id/255/cat_id/37
Hope this helps.
Feb 06, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Stopped heating
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is the heart of the oven that produces the RF energy that is used to heat your food. In order to replace a defective magnetron, you will need to consider the following:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. Ensure the oven is UNPLUGGED before servicing anything inside the cabinet and remove the exterior case in order to access the magnetron. There are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com
pcappliancerepair.com appliancepartspros.com
NOTE: If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
3. The magnetron replacement part number for the model you have listed is 2B71165R and is listed as item 5009 under the Internal Parts I listing. The average cost is about $70.
If you microwave oven does not run at all, the likely source of the problem is either a blown line fuse or AC line filter board. The line filter and fuse are accessible by removing the exterior case. The assembly is located at the point where the power cord enters the oven. The filter board is listed as item 5041 under the Internal Parts II listing and the line fuse is listed as item 5001. The part number for the Line Filter board is EAM35001801. The part for the fuse is 3B74133Q. You can usually purchase an entire box of fuses at your local hardware store for a better price. 125V, 20AMP, slow blow fuses are recommended. This model also has a thermostat (bi-metal) that if tripped, will also cause the oven not to heat or run. The thermostat acts as a fuse if the magnetron overheats. The part number is 6930W1A003E and is listed as item 5016 under the Internal Parts II listing. You will need to remove the thermostat from the oven and take a resistance check across the component terminals to determine if it is good or not. A low resistance reading indicates a good thermostat. An infinite reading, indicates a blown thermostat and needs to be replaced. If the oven cavity has overheated, it can sometimes trip the thermostat. Some of these thermostats will reset themselves when cooled down, some do not. Items such as baked potatoes, steamed vegetables and pop corn can often cause the oven cavity to overheat if the cook times are long, or if you cook several itmes in rapid succession. Its best to allow the door to stand open and the oven cavity to cool between cooking any food that make give off steam. Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful.
NOTE: If your model number is not listed at all the websites I have listed, use the part numbers from the Sears site to cross reference. In many cases, the model number may not cross reference to all websites, but the part numbers will.
CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts!
Dec 22, 2010 | LG LMV1630ST Microwave Oven
I need to replace the speakers for my RT2360 System, can you recommend a source for this?
rca is no longer the same rca that built that stereo ---as a result there arent parts available--i work for an rca servicecenter --all thats available are tv parts --i recommend shopping for generic replacements at either mcm electronics or parts express --both have thorough websites and comparable replacements
Sep 03, 2010 | RCA RT2360 System
Shorting out
Hello m606walsh,
From what you've said, it sounds like the coil is expanding due to heat (or perhaps other stresses, can't tell without looking) and getting too close to the inside case, resulting in scorch marks.
You may not need a new coil - - try adjusting the one you have so it's not so close to the case. Since you didn't say so, I'm presuming that the case isn't so badly scorched that it needs replacement as well.
I'm not finding a heat coil in my usual list of spare-parts sources either, so finding genuine OEM parts may not be an option, but here are the three possible fixes that seem reasonable.
1) Contact Oster - - the Breadmaker 800# is 800-438-0935 - - and ask about their recommendations for parts or repair. They will likely not want you doing electrical repairs yourself, and will probably refer you to a service center.
Here's the URL for their Service Center Finder page:
http://www.oster.com/CustService.aspx?content=center
2) Consider buying either
- a used machine for parts (I'd start by hunting on eBay or other online auction sites like PropertyRoom.com
- a new machine and use your old one for parts (aka cannibalism).
I've used this strategy on both cars and computers - - often makes more sense than trying to hunt a spare part when you need it.
3) (I don't really recommend this unless you want to make this a hobby/quest) Pull the part and start visiting local appliance repair shops to see if it's an "off-the-shelf" standard OEM part. This can easily take more time than it's worth - - new breadmakers of this model are going for ~$70-$80 (plus shipping) on eBay and other online sources.
If I can be of further assistance, let me know.
If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 23, 2009 | Oster 5838 ExpressBake Bread Maker
Shorting out-5838 oster breadmaker
Hello m606walsh,
(This is a copy of the response I posted in your other message - - don't know which one you wanted to use - Jon)
Jon
Olevia LT42HVi 42 in. LCD Television Logo
209 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
