Question about Microsoft Xbox 360 Console
Xbox 360 is on , but no Picture/Sound
Problem :- No sound/Picture
I was playing a game today on my xbox 360 and the screen suddenly started going reddish - now I could still play my game the graphics(colours) started to go a bit wierd , like a tint of red and the green was went brighter . It started to go a little bit blurry . The console remained the same i.e. no red lights , no funny sounds .
I pulled the cable out just a little bit and the screen returned to normal for a duration of no longer than 10 seconds . It then returned to red blurryness and small red lines etc however the game was still playable .After the problem persisted , I went and turned the console off . When I switched it back on it started up fine i.e. 'no red ring' or 'funny sounds' . All the lights were on as normal however - their was NO sound & NO picture .
I have tried unplugging all the cables and replugging them . I've tried plugging the cables into different scarts in the back of the TV i.e. the different audio(red/white) sockets . I've also tried just playing it in NON HD i.e. removing the 3 other cables and just having the red,white and yellow one plugged in - this still didn't display/play anything .
I'm in desperate need of some advice on how I can solve this problem ?
Background to the Xbox 360 :- I've had it since the day it came out , it's the original not the problem prone preminium and I've never had any problems before with it .
  • AJD30 Dec 18, 2008
    Pretty much the exact same situation happened to my XBOX about a week ago. The graphics started to change as if it looked more like a watercolor painting. I immediately turned my console off and left it off at least 24 hours. When I started the console back up again, there was no sound or picture. Using the controller, I can still turn the console on and off without any problems. Just no picture and sound AT ALL.
  • Cameron Braswell Dec 18, 2008
    I as well have this problem, actually has had it for a while. Anyone else that has had this problem has done what everyone has- curse aloud, look for an answer on the net, and once none is found call microsoft, and once learned that they won't fix this (because it is not covered in the warranty) curse even more.
    All I know is that this is something to do with the motherboard, so more needs to be done to it than just some idiotic "towel trick" that may or may not work. Until the everyday guy finds a solution for this problem for us, our best bet is to either buy a new one, buy a broken one from ebay and salvage the motherboard (if possible) and work on it, or take it to a game shop (not a game store like Gamestop, the hole-in-the-wall shops) and pay $50 for them to fix it.
  • 4 Answers
DO NOT USE THE TOWEL ONE!!!
THE TOWEL ONLY HEATS IT UP MORE AND THE 2 X CLAMPS INSIDE WILL VIBRATE ONLY 2 MAKE THE MAIN XBOX CHIP 2 COME OUT OF ITS PLACE.... SO THIS IS WHAT U DO!!! First Get a Screw driver and take out the covers of the xbox and ull see a metal sheeting. Then take out all the screws from the metal board. then take out the other things (take out the fan last) Then If its the graphics chip thats broken then u need a new one but if its out of place, replace it and put the xbox bak 2gether. The  the prob shud not happen again. This is what happened 2 me only last week. it shud only take 30 mins 2 fix.
But the other prob could be the cord cause the cord might be old faulty or broken cause my friend had dat prob.
Posted on Apr 17, 2009
Alright dudes here we go. If you look up further on this thread i HAD the same problem. This is how i fixed it. I needed it to red ring so i could send it back in to get replaced since my 1 year warrenty was up. But i fixed it instead. So here is how you do it. First i took off my hard drive on the 360. Then i pluged it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) i only say this because i didn't use the HDTV setting to fix it. then i pluged it into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on i took 1 towel folded it long ways and wraped it around my 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. mine has been working for 3 days now with no problem i even have it hooked up using the HDTV cables in my living room. if this don'ts help you now you have a red ringed 360 and you can send it in to get repaired since there is a 3 year warrenty for red ringed 360's.
It most likely is a poor solder connection on the motherboard at the video input.. I had the same problem and had success reheating with a soldering iron the pins near the hdmi port on the board.
Posted on Jan 02, 2009
    Scholar:
  • 31 Answers
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio but no picture/sound, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Posted on Feb 20, 2009
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays for a few minutes and then the screen goes black with no sound or picture.
your graphics processor IC chip needs its solder joints reflowing, and the heatsink re securing.
This will solve the problem.
Regards
FixMyConsole
May 19, 2009 | Microsoft Xbox 360 Console
Sound, but no picture!
1 leads are in the wrong way i hav had the same problem move ur leads around or go and buy a hd lead i pad 9.99 from blockbusters for a hd lead its worth a try
Mar 02, 2009 | Microsoft Xbox 360 Console
Video problems
We offer a repair service for this problem. We are listed on this site for repair.
www.videogamerepairservice.com
Feb 01, 2009 | Microsoft Xbox 360 Console
Xbox
if its less than a year old phone Microsoft customer support.
if not it could be early signs of 3 red lights
Jan 17, 2009 | Microsoft Halo 3 for Xbox 360
Sound, but no Picture
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio , video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
Dec 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
Xbox problem
disconnect the av cables and clean the caseing around them and on the back of the 360 try that and see if that works also is there any red lights on the system? if so please advise.
Aug 10, 2008 | Microsoft Xbox 360 Console
Why is my xbox 360 is not woking?
I've fixed that problem several times now with a great xbox 360 repair guide
Mar 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
641 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
