Question about RCA PDP 2812 (5 GB) MP3 Player
Playlists Is there any way to convert a playlist created with windows media 11 to a playlist that will run on the mp3 player?
  • 4 Answers
SOURCE: Can't get playlists
the only playlist u can create with it is the MySel list.. u cann add songs in this list in ur player by choosing the "Add to MySel" option
Posted on Apr 02, 2008
SOURCE: Compatability issues
Posted on Aug 03, 2008
  • 7 Answers
SOURCE: making a playlist
if ur talking about creating a playlist with a whole lot of different dongs under one title then all u have 2 do is hold down (or in) the analog stick over the title or artist of that song then go to the playlist options and the should be there u can also save and rename the playlist rather than playlist01. now maby u could help me with a prob i bought my rca lyra rd2765a and now my memory is full so i need 2 know how 2 delete songs or even format every thing, also i downloaded a whole bunch of nirvana sonngs awhile ago and now when i click to listen nothing happens i can only view the titles if u have a recommendation plz send me a email at thnx
Posted on Aug 14, 2008
  • 159 Answers
SOURCE: will not load files by playlist, will only load alphabetically
When you turn on the mp3 go to the setting and you can choose how the songs load, Name, artist, size, alphabetically, chose the ones you want on. And turn the other off.
Posted on Jan 08, 2009
  • 26 Answers
SOURCE: RCA M42 series mp3 player playlist
try creating a new fold inside your music file that all your music shows up in and say call it Myplaylist then drag other songs into there and see if it shows up
Posted on Jan 14, 2009
  • 133 Answers
SOURCE: RCA m4204 mp3 player playlist issue
This model does not support playlists, but in the event they ever do supply an update with that fix (rumor has it they will!) then it will be located under the "Favorites" section in the mp3 player.
Posted on Oct 07, 2009
Testimonial: "This answered it all. TY!"
0 characters
1 Points
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
I have a Sansa e250 but i lost the cd with the software on it. I forgot how to put music onto it, do i have to convert it first? Please help!
All support for Sansa e200 players can be found here:
Music transfers can be done, connected with the provided USB cable in 2 modes:
MTP = Media Transfer Protocol, when using a software program or Windows Media Player (10 or higher). In WMP10 or 11 select Library or Sync to create playlists and synchronize the playlists with the player.
MSC = Mass Storage Class, when using Windows explorer, viewing the player as a removable disk. Perform "copy and paste" or "drag and drop" actions onto the external USB device (drive letter memory with 2GB capacity).
For pictures and video use software program Sansa Media Converter on the computer. After conversion in SMC transfer media onto the player.
Use next overview link for information about and how to get Sansa Media Converter:
Need more help ? Just add a comment in this thread.
Mar 31, 2010 | SanDisk Sansa e250 MP3 Player
How to create playlist on e260 sandisk sansa pm3 player
this is from sansa website FAQ... check it too for ur other concers... well i hope this is what ur looking for...
How do I create and transfer playlists into my MP3 player using Windows Media Player 11?
STEP 1 – Create a playlist
  1. Run Windows Media Player.
  2. Click Create Playlist located in the top left corner.
  3. Type in the name of your playlist.
  4. Drag and drop music files into the Playlist Window.
  5. Click Save Playlist to save the list.
STEP 2 – Transfer the playlist to your device
  1. Click the Sync tab on the top bar.
  2. Drag and drop your playlist from the left window into the Sync List window on the right.
  3. Click Start Sync.
Sep 13, 2009 | SanDisk Sansa e260 MP3 Player
How do I to add a playlist
It's funny how Sony phrases it - you must use Windows Media Player 11 to transfer playlists to your device, but it may not work properly. Go to the Sync tab of WMP 11 - notice how it says drag playlists here to synchronize to your device. Once you have dragged the playlist over, hit Start Sync.
Mar 07, 2009 | Sony NWZ-E436F MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Try using Windows Media Player 11, to solve your issue it is a free download.
Jun 29, 2008 | Coby MP-C7085 MP3 Player
Probelm with playlists
The Vista compatible software may work different, but I have mine set to Repeat OFF, and I have no problem with playlist play. Is it possible that the songs that you put on your playlist are in the wrong format? If they were streaming files, or DRM-encrypted WMA's, there may be issues with playback. Convert the songs in your playlists to mp3 format ON THE COMPUTER, and then delete the playlists that are not working OFF YOUR SANSA. And then re-add the playlists to your Sansa.
-Tha Mp3 Doctor
Jun 03, 2008 | SanDisk Sansa Clip MP3 Player
Seperate Playlists
Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
May 31, 2008 | Philips SA1100 MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Sorting music, rename & creat playlists problams
Provide more info 1/ what windows OS R U Using/2 H10 requires Windows Media Player ver 10 3/ If you do not have XP to run WMP10 then connect H10 in UMS mode, transfer audio files and playlists using windows explorer 4/then use EasyH10 to update the database on H10
Dec 25, 2006 | iRiver H10 MP3 Player
RCA PDP 2812 (5 GB) MP3 Player Logo
14 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
