Question about Canon imageRUNNER C3220 Color Copier
Imagerunner5570 Code Number E000025-0002 At start-up, the machine display only displays a shutdown option with the above code changed.  It says to shutdown and restart, but that does not help.  At restart, the same display and code are shown.  PLEASE HELP!!! Thanks, Stacie Fowler Bemiss Printing mcprintingart@bellsouth.net 229.249.8777
  • 679 Answers
Ok I searched for fixes, this sounds simplistic but shut it and leave the plug fo a minute, meanwhile I'll look for more solutions if it doesn't work, ty Gym
Posted on Dec 18, 2008
    President:
  • 2,110 Answers
The error indicates a high voltage problem with the primary or transfer units. The most likely cause is the main drum being worn out.
This can be checked by going into service mode. You can do this by pressing the star button once, then press 2 and 8 at the same time, then the star button again. Now a word of warning. Do not change anything as it is very easy to turn your copier into a cabage!!! Press the tab marked COPIER, then the one called DISPLAY, next the one called MISC. You will see an item called DRUM LIFE, if it is 80 or more the drum will need replacing. Hope this helps.
Bizhub c6500 error code C-3913
Check the fusing position, check all connector, make sure everything oke, and doing this adjustment:
Utility => Stop => 0 => Stop => 0 => 0 => 1. This is to prevent accidental reset of the code and causing additional damage to the machine. To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen. 5. Press [01 Software SW setting] on the touchscreen.
6. Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
Dec 22, 2016 | Konica Minolta Bizhub C 6500 Copier
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
Retreving calls from another phone uaing my code does not work any longer. I would like to reset the code. Please give instructions. Thank You,
Changing the Remote Access Code The Remote Access Code is preset to 500. You can change the Remote Access Code to any three-digit number from 500-999. DO NOT pick the same number as that assigned to the Priority Calling Code. 1 Press g. The Message Window displays CH. 2 Hold down c for at least two seconds. The system announces "First digit." 3 Press / or ? to change the digit. 4 When the Message Window displays the desired first digit, press c. The system announces "Second digit." 5 Press / or ? to change the digit. 6 When the Message Window displays the desired second digit, press c. The system announces "Third digit." 7 Press / or ? to change the digit. 8 When the Message Window displays the desired third digit, press c. The system announces the new Remote Access Code.
Aug 26, 2011 | AT&T 1725 Answering Machine
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
I have a konica 7272 ... when i switch it on, i get this report code SC 34-01
1. Access the 25 mode 2. Press ...................................1: Software SW setting 3. Press the left up-arrow, which is displayed on the touchscreen, twice. The number displayed above the up-arrow will change to 03. 4. Select the bit number of switch 1, using the right up-arrow. 03-1 will be displayed. 5. Press the OFF key, displayed on the touchscreen. 7. Power the machine OFF/ON
Note:If you are not a technician, better call one.....
Dec 22, 2010 | Konica 7410 Laser Printer
I have Canon IR-C5185i. Just assembled out of the box. Powered on. Message displays with error E0000732-8888 and I am instructed to ''turn switch off and on''. What could be wrong?
When this machine was started after connecting the Color Image Reader-E1/F1, the screen for the shutdown sequence appeared (and E732-9999 was recorded as an error history in service mode). When the main power switch was turned OFF/ON by following the instruction on the screen, the error code "E732-8888" was displayed. When connecting the Color Image Reader-E1/F1, follow the field remedy below.
- E732-9999 is recorded when a printer model detects a scanner for the first time. (This is not an error code but an alert.)
- E732-8888 can be displayed when a different scanner is connected to this machine.
1. Connect the Color Image Reader to this machine. (Do not connect the DDI cable).
2. Turn ON the main power switch.
3. Change the setting values of the following service mode items.
- Service mode > COPIER > Option > BODY > W/SCNR: from '0' to '1'.
- Service mode > COPIER > Option > BODY > SCANTYPE: from '1' to '0'.
Reference: For the Color Image Reader-E1/F1, this mode has to be set to '0'. On the other hand, it has to be set to '1' for the Duplex Color Image Reader-G1.
- Color Image Reader-E1: Platen cover model
- Duplex Color Image Reader-F1: Two-sided reversal reading type ADF model (DADF-M1)
- Duplex Color Image Reader-G1: Two-sided simultaneous reading type ADF model (DADF-T1: only for the iRC5180)
4. Turn OFF the main power switch, and connect the DDI cable.
5. Turn the main power switch ON.
Note: How to turn OFF the main power switch.
When turning off the main power switch, be sure to follow the steps below to protect the HDD inside this machine.
1. Hold down the control panel switch for 3 sec or more.
2. Following the instruction displayed on the shutdown screen, operate the control panel. (The main power switch is turned OFF automatically.)
3. If there is a need to unplug the power cord (from the wall outlet), perform step1 and 2 above before unplugging it.
Nov 17, 2009 | Canon Office Equipment & Supplies
Can not shutdown /CPU fan allways working
Try the following command......
shutdown [-i | -l | -s | -r | -a] [-f] [-m \\computername] [-t xx] [-c "comment"] [-d up:xx:yy]
No args Display this message (same as -?) -i Display GUI interface, must be the first option -l Log off (cannot be used with -m option) -s Shutdown the computer -r Shutdown and restart the computer -a Abort a system shutdown -m \\computername Remote computer to shutdown/restart/abort -t xx Set timeout for shutdown to xx seconds -c "comment" Shutdown comment (maximum of 127 characters) -f Forces running applications to close without warning -d [u] [p]:xx:yy The reason code for the shutdown
u is the user code
p is a planned shutdown code
xx is the major reason code (positive integer less than 256)
yy is the minor reason code (positive integer less than 65536)
Do reply me if it sort out your prob
Sep 30, 2009 | Abit SG-71 Motherboard
Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Jan 23, 2009 | Office Equipment & Supplies
Code F34-1 means for a Konica 7065
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon imageRUNNER C3220 Color Copier Logo
166 people viewed this question
old marine
old marine
