Question about Gigabyte GA-7VRX Motherboard
GA-7VRX Motherboard won't boot
Good evening,
I just bought a new motherboard and processor (the cpu is an AMD XP 2500+) but when installed, the system won't boot up.
What happens is this:
The CPU fan turns for a second but then stops, nothing else is booting up either.
After that failed, an orange LED is lit up and stays lit up on my motherboard.
Power jumper is where it's supposed to be, but I don't know what the problem could be.
Thank you for our help :)
  • sebaswis Dec 19, 2008
    Hey Mike,
    thank you very much for trying to help me solve this and actually reading my mboard manual :)
    I have to clarify one thing though and I'm sorry if I didn't make that clear in my earlier post: I replaced my old motherboard with this new GA-7VRX one. (My old one was a also a Socket A processor, but an older one)
    (Now I've tried to take my old cpu off my old mboard and then try to exchange the parts to see what the matter is, but it appears my old cpu is 'stuck' in my old motherboard. But that isn't really the issue here XD)
    I'll try disassembling the heatsink soon (problem is I'm going on vacation for 4 days - perfect timing, I know :P)
    What kind of bothers me is that my old mboard had an ATX12V connector whereas the new one doesn't...
    You mentioned my mboard might be shorted to the case? I did everything I've done with all other mboards I've had (and again with the one I put it and worked fine) so I don't know if that could be it. But that might explain it, yet I don't really know how I could test that out.
    Thank you for the mboard link btw: It was helpful in that it showed me all the steps that I had done and done correctly.
    Please get back to me if you can. While I will be on vacation, I will still have internet access, just not the CPU and mboard to tinker around with ;P
    Happy holidays and thank you :)
    President:
  • 2,351 Answers
Hi sebaswis, am I correct that this Gigabyte GA-7VRX is a replacement MB? (I read your other posted questions). http://www.fixya.com/support/t1399506-computer_boot_when_power You mentioned you put your old system back together & it worked fine. If mother board is shorted to the system case you will see the CPU fan spin for a second. Most motherboards use a green led which represents there is stand-by power running to the board.(This is normal). I am unsure why your led is orange. (Its not mentioned in your manual & manual does not show the led?s location). Was the other GA-7VRX MB led always orange or was it also green? Suggest you disassemble the heat-sink from the CPU. You mentioned you installed a new XP 2500+ CPU. If a pin on the CPU was bent during installation of CPU into the socket or if no thermal grease was applied or too little to the top of CPU, either would give you: CPU fan spins for a second & nothing else seems to run. Look over the link provided below. It is a guide to how to install a motherboard. (You may not need this but Its worth going over all the steps). http://www.hardwaresecrets.com/article/145 As far as the power supply. If the MB's are the same (GA-7VRX) & the old system ran with 220W, the newer one should also function. Clarify these questions for me sebaswis. Mike
Posted on Dec 18, 2008
  • Mike Peluso
    Mike Peluso Dec 19, 2008
    Hi sebaswis, thanks for adding more information. I wouldn't run anything lower than a 300W power supply on this board.
    Back to the CPU. I looked up the specs for the CPU:
    http://compreviews.about.com/od/cpus/l/a...
    Go to the bottom of the page.
    Try setting the MB switches for the CPU to the default settings first & than try booting the system.
    If the system does not function than change the switches to:
    Set SW1 switch to, "1:CPU CLOCK." (Using the CPU FSB).
    Change, CLK_RATIO to 11.
    The FSB of the CPU is 166MHz x 11. = 1826MHz. If you set the ratio to 11.5 you'll go over the CPU max speed. 11.5 would force the CPU to run at 1909MHZ.
    That would be known as over-clocking. See if the CPU & fan runs.
    Allot of ATX power supplies that come with a 24-pin_12V main MB power connector can still be reduced to a 20-pin_12V connector.
    Like this one: (The added 4-pin end can be separated but not completely removed, you just don't plug it in).
    http://www.tigerdirect.com/applications/...
    Enjoy your vacation!
    Merry Xmiss.
    Mike
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
Ga 7vm400am motherboard
yes they are both 462 pin socket a processors and you have a socket a motherboard
Apr 30, 2010 | Computers & Internet
Upgrading an OS on a GA-7VRX now orange LED and will not boot
Sounds like you've stressed the memory out during the upgrade, try just 1 stick at a time and see how that goes......please let me know ....cheers from Scott
Apr 14, 2010 | Gigabyte GA-7VRX Motherboard
I load window 7 on this system it works good but before that i try loadig windows xp service pack 2 and 3 everytime i reach to format the hard drive the system just shut dowm i think i have to change my...
you processor over heats. make sure the processor fan is working fine and remove the processor and replace the cooling paste and fix it again. refix the rams.. now it will work
Jan 15, 2010 | Gigabyte GA-K8VM800M Motherboard
I installed the windows xp sp2 64bit, my system not good work. i used the gigabyte motherboard GA-MA78GM-US2H with AMD QUAD X4 PROCESSOR. not good working my system.. plz help me..
it should work fine .there may be woring instaling prosses. some high configreation computer not work it means in ashort periode xp- can crash as in 4 gb ram. please try sp -3 .it can help u.
Oct 25, 2009 | Gigabyte GA-MA78GM-US2H Motherboard
My AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Sep 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
My 7vRx can not start Windows...!?
Did the computer work normally after getting it back from the repair technician? Although there are other causes, the symptom that you state (stops at stage of starting Windows setup) may indicate a memory problem. Download memtest86 and run it from boot.
Also. you may have conflicts betwen the cpu and memory. If you set the system switch on the motherboard to 133MHz, you should check your BIOS (under Hardware Monitor and misc.setup) to see if the CPU Host Clock is set to 133MHz. Also, set the CK_RATIO dip on the motherboard to "auto".
Another thing to check in BIOS is the interupt mode...set it to APIC. The PIC setting will hang on XP. Don't forget to save changes on exit.
Your BIOS may be corrupted. When in BIOS, check to see if you are running main or backup. If it's running backup, use the AUTO RECOVERY feature to restore the main BIOS.
Your problem might be solved by just re-setting the BIOS by selecting "LOAD optimized defaults" on the main page.
There may be other solutions, but try these first. Please don't rate this post until we explore other possiblities.
Feb 07, 2009 | Gigabyte GA-7VRX Motherboard
Computer won't boot. When power switch is pressed, CPU fan turns for a second but then stops. Nothing eles boots up, but an orange LED lights up and stays lit up on the motherboard. Motherboard: GA-7VRX...
1st. check your memory sticks, if you have two, flip\flop them around. if you can replace (don't buy them if you can until you are sure that they are damaged) or substitute them for a "lower" value & frequency range. Just to see if the computer turns on.
p.s. are putting the computer together for the 1st time?, Was the computer working before the problem? if so you could have said so!
Dec 18, 2008 | Gigabyte GA-7VRX Motherboard
Installing P4 2.8ghz cpu
That particular motherboard only supports AMD processors:
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=1764
You will need a new motherboard to use your Intel 2.8ghz chip.
May 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
System will not boot
The CPU failure was possibly due to a Power Spike, if that was the case then the Memory or Motherboard may also be damaged,  it may be best to test the CPUs and the memory on a known working system, to see what is working & what is not
Oct 13, 2007 | Gigabyte GA-K8VM800M Motherboard
Gigabyte GA-7VRX Motherboard Logo
375 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
