Question about GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650 Microwave Suddenly Stops
Same problem as jayg714: microwave runs a few seconds, stops (no beeps), and then a garbled display. Need to re-enter date and time. If I try again immediately, it happens again; if I wait awhile, it seems to work. This has happened 3 or 4 times in the past few weeks. The unit is about 2 years old. Suggestions?
  • tamimd Jan 12, 2009
    Dear Brian: I have the same issue. I contacted GE. They are refusing to send me the mag tube because I am not a service technician. Is this tube really dangerous for the average person to install? Thank you! Tami
    Scholar:
  • 111 Answers
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Posted on Dec 20, 2008
I HAVE A NATIONAL MICROWAVE WHICH STOPS AFTER TWO SECONDS
MAY BE DEFECT IN MAGNETRON SECTION MAY BE HIGH VOLTAGE NOT COMING FROM HIGH VOLTAGE UNIT OR MAGNETRON
Jan 12, 2014 | GE JVM1650 1000 Watts Microwave Oven
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
I put my Microwave on for 30 min and it suddenly stopped working, suggestions?
If there is no power at all to the display or the panel then it is failure of the board. But if there is power without heating, if the turntable/fan/light works, then it can be related to failure of relay, Magnetron, Waveguide or capacitor.
Jan 31, 2013 | GE JVM1650 1000 Watts Microwave Oven
Sensor goes off inside microwave after 10 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 03, 2012 | GE Microwave Ovens
We have GE JVM1650 spacemaker microwave. At first it would run for 3-5 seconds and turn off. More recently it stopped heating in the middle of the alotted time. Everything works fine, no keypad...
It's a bad magnetron.
See
this FixYa solution even if your full model number is different.
Oct 02, 2010 | GE JVM1650 1000 Watts Microwave Oven
Tami,
It isn't really difficult to replace... It's the 4000 Volts that go to it and the stored energy (voltage) in the high voltage capacitor that concerns me as far as telling you that it is a do it yourself repair. Also, and this a huge concern, is that after the magnetron tube is replaced, the microwave should be leak checked. A microwave leak detector that is certified is around $400. Now that I said that, I have rarely ever had one that leaked, but it is the law and that's the main reason that it needs to be done. I highly recommend calling GE Factory Service 1-800-432-2737 (1-800-GE Cares) to install the magnetron tube.
Brian
Jan 15, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 truntable noise
Sounds like the turntable motor is going bad.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE JVM1650 1000 Watts Microwave Oven
The microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Oct 03, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Sep 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
176 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
