Question about Lexmark T522 Laser Printer
Diamonds on the T522 LCD
I flip the switch of the Lexmark T522 and I get 2 rows of daimonds across the LCD display, but no post(motor function). It does move beyond that point. I have already installed a system board with no better reults.
  • Anonymous Jan 14, 2009
    Yup I have the same problem.
    The printer will not make any noise.
    No POST, just 2 Rows of Diamonds.
  • 320 Answers
Do you get 5 beeps when the printer powers up? three things can cause this the control panel, the logic board and the engine board if you have replaced the logic board the engine board is the problem change that and your problem should go away
Posted on Nov 28, 2009
  • norman steach Dec 07, 2009
    all diamonds in the display means un completed post. do you get 5 beeps? this can be created by the control panel or the logic board. usually the logic board is the problem
Can i have 100 daimonds lol plz I WANT SOME
You might get some " Diamonds " if you new how to spell correctly !
Try it , it may get you "on the up "
Mar 12, 2015 | Cars & Trucks
MSI 760gm-p21(fx) MB, JFP1 AND JFP2 PINOUTS I NEED TO SEE A DIAGRAM SHOWING ME EXACTLY WHERE TO PLUG the cables on the MB
http://www.msi.com/product/mb/760GM-P21--FX-.html
Hover your mouse cursor on the Download tab.
(Overview/ Specification/ Download/ Support/ Where to Buy)
In the drop down list click on - Manual
On this page under the subheading Download, click on the blue -
M7641v3.0.zip
On the next page click on the country name nearest yours.
Motherboard User Manual.
This is a Zip file. If you do not know how to open a Zip file, please state in a Comment, and I will guide you.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is divided into two headers on the motherboard.
This you have stated, JFP1 and JFP2.
(Junction Front Panel 1, and Junction Front Panel 2)
JFP1 is for the Power On switch, HarDDrive activity LED, Reset Switch, and a two wire Power On LED.
JFP2 is for an internal speaker/buzzer, and a three wire Power On LED. (Dual color)
JFP1:
4 pins across the Top row.
5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side coming across to the Right side, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting on the LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is reserved for the factory to use.
D) Pins 2 and 4 are for a two wire Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO pin 10.
JFP2:
3 pins across the Bottom row.
Starting on the LEFT side coming across to the Right, Top row;
Pins 1, 3, and 5. There is NO pin 7.
A) Pins 1, 3 and 5 are for a dual color Power On LED.
Pin 1 is for the Negative ( - ) wire.
Pin 2 is for a Yellow, or Orange part of the dual color Power On LED.
Pin 3 is for a Green part of a dual color Power On LED.
B) Pins 2, 4, 6, and 8, are for a speaker/buzzer.
Pin 2 is for the Negative ( - ) wire of a speaker.
Pin 8 is for the Positive ( + ) wire of a speaker.
Pin 4 is for the Positive ( + ) wire of a buzzer.
Pin 6 is for the Negative ( - ) wire of a buzzer.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 28, 2012 | MSI Computers & Internet
I have just received a lexmark t522, which was an ex-work printer that was attached to a network. i want to use it as a stand-alone printer now. when it was attached at work it worked fine, but now keeps...
This printer has both a USB and parallel printer connection.
I suggest you connect this printer to your computer using the USB printer cable and install the printer driver software on your computer.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Aug 03, 2011 | Lexmark T522 Laser Printer
Lexmark T522 printer I need to go into Tech Mode to move the Paper Down so that it does not clip the list line. I know you turn it off and then perss 2 buttons and hold them while starting it...
hold the go and return buttons while powering up the unit it will come up to registration hit select this is where you adjust the laser lock of the scanner
Oct 23, 2009 | Lexmark T522 Laser Printer
I have a lexmark t522 printer which was working fine about an hour ago but now it won't even power on. Can you advise what you think the problem may be
do this disconnect the scanner motor plug from the engine board this plug is at the top of the engine board it will be either all white strands or blue black and red standed wires. then see if it powers on. this sounds like the scanner motor is dieing and is shorting out when it gets warm.
Oct 02, 2009 | Lexmark T522 Laser Printer
Display issues with Lexmark X125
LCD displays have one potential weakness (other than freezing temps), and it involves how they are contacted. The display has a row of sputtered contacts which are nearly transparent that carry the date from a flat cable to the display segments. These film contacts cannot be soldered and the mating 'connector' is a flat piece of silicone rubber with fine parallel wires embedded within. This is a narrow strip with the conductors running across the width of the strip. One side is pressed against the film display contacts, the other against bared conductors of the data cable. These are held to the display's contacts by pressure and the initial alignment is critical as is the consistency of pressure across the row of contacts. Sometimes, this is either not well-braced to avoid the loss of contact or heat can cause their position to drift enough to cause some of the display segments to 'drop out' or, if a supply contact fails, you can have either a totally blank display or one with ALL segments turned on; this latter condition is yours.
If you feel like experimenting and can gain access to the rear of the display, you may be able to influence this problem by loosening or tightening any screws you see holding the flat cable to the back of the display.
If you decide to try it and are successful, it may help others if you would return to this thread and give us a description of your work.
May 07, 2009 | Lexmark X125 All-In-One InkJet Printer
Lexmark t522
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 13, 2009 | Lexmark T522 Laser Printer
I am getting error 200 on a t522. This is being used as a repacement for another t522 which is displaying 'Std Bin Full' message after inreplacing fuser Thanks Michael Cotter
where the paper spits out , there is a little arm that is stuck in the up position. maybe the spring came off. You will have to take the top cover off to see this.
May 28, 2008 | Lexmark Office Equipment & Supplies
Lexmark T522 Laser Printer Logo
237 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
