Question about Kodak Dock Series 3 Laser Photo Printer
Lines in prints
I just got my printer dock, and it printed off about 5 pics then i started getting pics that came out with lines through them,, is there any way to stop this? becasue i bought it in a set with a camera and dont want to take it back,
    Sergeant:
  • 390 Answers
Lines in printouts indicate lots of issues. Clogged printheads...even in a new printer, damaged cartridge, or air bubbles in ink. Take out the cartridges, clean the heads and the docks printhead, replace and try again. If no success, try standinf the cartidges upside down on wet paper towel, and bleed ink a little. This eliminates air bubbles. Try printing now. Clean heads with printer program too. If still no success, follow consumer rights which says you are entitled to a product doing what it says it should for a reasonable amount of time (if it turns out to be a faulty dock. Try a new cartridge too after claening to eliminate damaged cartridge.
Posted on Aug 11, 2007
Kodak easy share printer dock 3
sounds like its only receiving half the data. try these step... uninstall printer from your device... reinstall printer to device... if youre using a smartphone or tablet, switch to a pc... press and hold the cancel button on the printer... turn it off for 60 seconds then power it... run the nozzle cleaner function, then try again
Jul 05, 2016 | Kodak EasyShare Printer Dock Series 3
When I print pictures on my kodak g600 easy share printer dock I get faint streaks(lines) on the pictures I have printed.
right click the printer, select properties, and select reset cartridges or print a test page.
Jun 15, 2011 | Office Equipment & Supplies
Computer can't find driver to communicate with printer
can you check if you have the CD that came along with the Kodak Printer? You would need that to install the printer on your computer. Once thats done, you should be able to print the pics
Hope this helps
Thanks
Ranjit
Aug 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Cx7430 printer dock does not print a full pic., top is not printed
Hi,Try the following sites to short out your problem…..
http://uw713doc.sco.com/en/PR_admin/prntT.NoPrint.html
http://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_5.htm
http://www.smartcomputing.com/editorial/article.asp?article=articles/archive/r1101/04r01/04r01.asp&guid=
Thanks
Nov 24, 2008 | Kodak EasyShare CX7430 & EasyShare Printer...
Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | Office Equipment & Supplies
I AM TRYING TO TRANSFER PICS FROM CAMERA THRU EASYSHARE PRINTER DOCK,TO PC,SO I CAN EDIT AND PRINT PICS,TRYING TO FIND THE SIMPLEST WAY BUT NO SUCCESS,PLSE HELP THANKS
Remove software installed.
Do not use the Dock
Connect camera directly USB to USB
Let the computer do the rest
Still in trouble by an externnal USB card reader
Jul 21, 2008 | Cameras
Picture dock
Go to Start/Control Panel/ Add remove software.
Remove the Kodak Easy share software.
Do not re install it.
Use USB cable to connect camera to computer
Use alternative software [picasa which is Free] or any other image editor for processing and printing images.
It is likely your printer has supplied software that is suitable.
Jul 08, 2008 | Kodak EasyShare Z650 Digital Camera
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak printer dock series 3
make sure the external card is activated, and make sure the pics reside on your pc, if you are trying to transport directly from an outside web source to the camera you'll just be confusing the computer. It may have worked at one time (luckily I may add) but by now the drivers are so corrupt that the process has fallen null. Otherwise reinstall the dock drivers to transfer the pics from a safe place on your PC to your Camera only. Good Luck!
Nov 04, 2007 | Kodak EASYSHARE Plus Series 3 Thermal...
After docking laptop I have to add port prior to printing
I assume you're running Win Xp. Disconnect the USB cable from the docking station. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. Double click on the Konica icon. In the print queue that opens, delete any pending print jobs. Go to START/CONTROL PANEL/ADD REMOVE PROGRAMS. Uninstall any Konica software. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. On the MENU bar, click on PRINTER/SERVER PROPERTIES. Click on the DRIVERS tab. Remove anything that says Konica. Click on the PORTS tab. Remove ALL the Konica ports. Reboot Re-install the printer driver - DO NOT plug in the USB cable until it tells you to. That SHOULD do it. If it does not, please let me know and I'll research it further. Ed
Jul 13, 2007 | Konica Minolta PagePro 1350W Laser Printer
Kodak Dock Series 3 Laser Photo Printer Logo
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
