Question about kawasaki Blue 3.5'' Kids' Portable DVD Player - PVS133B-B
Remote for pvs133b b not working
The remote that came with my portable dvd player is not working. This would not be a problem if the subtitle option was not turned on when it broke, but it is. I have tried changing the batteries but that did not help.
3 Suggested Answers
SOURCE: Cannot charge battery
My brother resolved the matter for me. Thanks
Posted on Jun 24, 2008
  • 303 Answers
SOURCE: Need charger for Kawasaki portable DVD player
click on hyperlink:
buy replacement ac power power cord charger adapter KAWASAKI PVS-10921
Posted on Jun 02, 2009
HOW CAN I SET UP THE SUBTITLE FOR MY DVD PLAYER
if their is an option in your remote controller, sub title then you can select an option setting in your dvd player.
Sep 09, 2012 | Panasonic Eur7621010 Remote Control
I lost the remote to my player,how can i remove the subtitles from the player manually?
Good day, usually for dvd subtitle the only option for you to get rid of the subtitle is using the remote control. But you can check the dvd player itself if it has a menu button which will allow you to access the subtitle but when i check it i didn't see any button. So i suggest for you to just purchase another remote if you really want to have the subtitles disable. Hope this information help you a bit. Have a great day.
May 24, 2011 | Koss KD365 DVD Player
Have no remote for the device.so i have been playing movies manually! how can i take off the captions.
Normally when a DVD is inserted, the subtitles option (if it appears in the on-screen DVD menu) is set to 'OFF' by default, but since you do not have the remote, you cannot access it. Some DVDs have the subtitle/captions enabled at startup, so there is nothing you do can do without the correct remote for this model (which may no longer be available anywhere) and it's even worse if the subtitles are not in English or the audio language is not English or both!
Nice to have a remote (universal one if you can find one which can operate this model) then you can have basic control over it, but I cannot assure you that it will turn subtitle/captions off per disc. Just one of those things - but you can look around for a universal remote (if it has subtitle button) and it might work. Or you can look around at secondhand remote/DVD decks online etc.
Up to you what you decide to do here. If it comes to the crunch, and you can no longer tolerate the subtitles being on all the time with each disc during manual playback, consider replacing the whole player (this is cheaper in the long term) - but only as a last resort, since Blu-Ray players (with DVD playback support) are becoming cheaper to buy. Something to think about later on if necessary.
Mar 28, 2011 | Cyberhome CH-DVD 300 DVD Player
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How do I get the words that show up on the screen during the movie to disappear
On the remote there should be an option for subtitle or "SUB". Have it pressed and it should provide you with different subtitle options. Some DVDs have more than one subtitle to support multiple languages. To remove it, set it to "OFF".
Dec 11, 2009 | Cyberhome CH-DVD 300 DVD Player
How do i turn on the english subtitles
there may be a subtitle button on your remote. After pressing if it doesn't work then there mayn't be subtitle available on your dvd disc.
Aug 23, 2009 | Audiovox D1718PK Portable DVD Player with...
How can I take subtitles off without a remote?
start the movie then go to menu then to language option the turrn subtitles off.
May 17, 2009 | Mustek MP72 Portable DVD Player
Hi, how do I turn the subtitles off on my dvd player - pushing the subtitle button just gives the 'english' option then says 'invalid key'. I can turn off subtitles on the actual dvd playing but still the...
Some DVDs can't change the Audio or Subtitles in Button of the Remote, try change in the Menu,
Try again with the Remote with another DVD Disc...
Bruno Gamba
Jul 22, 2008 | Televison & Video
Jun 23, 2008 | kawasaki Blue 3.5'' Kids' Portable DVD...
Televison & Video Logo
24 people viewed this question
Top kawasaki Televison & Video Experts
Davor Krstevski
Davor Krstevski
Jaime Hernandez
neOen
Level 1 Expert
Are you a kawasaki Televison and Video Expert? Answer questions, earn points and help others
