Question about RCA RS2635 CD Shelf System
Stereo Died I was listening to my stereo, and all of a sudden it turned off.I tried to turn it back on but it wont,I even tried switching plugs. What could be the problem and how can I fix it?
    President:
  • 3,130 Answers
It most likely blew a fuse as a result of the power supply or the power output curcuit blowing out. Unless you have the proper tools and the the right test equipment , I am afraid you will not be able to repair this as this repair will require you to have the circuit diagram and follow the short. My best advise would be if this unit cost less the a couple of hundred bucks, Time to go shopping, as the repair would most likely exceed half if not more. Good Luck
Posted on Mar 29, 2007
Why wont my stereo turn off in my car?
The door ajar switch must be defective and this is what signals the delayed exit control module to turn off the accessories
Nov 03, 2016 | Saturn Cars & Trucks
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
I was sitting at work with the engine off & the stereo on when i decided to listen to music from my iphone. As i plugged the aux cable in the stereo the lights on it turned off & nothing would work. I...
ok You may have a short in your headlights switch witch it also has ur internal light switch check ur relays I think that the problem if not do a short test go to youtube to know how to do that.
Sep 19, 2013 | Car Audio & Video
My 97 crown victoria died suddenly while driving down the road and won't restart
Is the fuel pump coming on? Turn the key to on position and listen by gas tank for a humming noise for fuel pump. Check the accident fuel shut off switch in the trunk, it should be on driver side in trunk, behind carpet- pad. if the button is up. Push it down to reset.
Oct 15, 2017 | 1997 Ford Crown Victoria
JVC KD-LX333 car stereo turns on, but then shut off and wont...
TAKE IT OUT AND TRY IT ON A 12V BATERRY AND IF IT TURNS ON ITS GOOD AND IF IT DOESNT IS NOT GOOD. IF IT TURNS ON FOLLOW UR CONSTAN AND UR POWER WIRES AND SEE IF IT HAS A FUSE BOX IN THE BOAT/ CHECK THOSE FUSES. AND CHECK UR BOAT BATTERY TOO CAUSE IT COULD HAVE DIED WHEN TESTING THE STEREO TOO IT HAPPENS ALOT ON BOATS
Jul 04, 2009 | Sony CDX-GT210 CD Player
No sound when radio is turned on
i have the same problem with mine..did u ever find out how to fix it?
Jun 04, 2009 | Sony MHC-GX450 CD Shelf System
Kenwood ktv617dvd Power shuts off then comes back on by itself?
It sounds like there is a short somewhere in your wiring. If the problem got worse when you installed the aftermarket stereo then it may be on the factory side of the plug. You may try powering the stereo by some other means. For example, try a wire with an inline fuse directly from the fuse block to the power wire on the stereo. You can also tap into the ignition wire that way the only way it will get power is when the key is turned on. Don't forget the inline fuse if you try it that way. I had to do that with a stereo I once had.
Mar 09, 2009 | Kenwood KVT-617DVD Car DVD Player
Sansa Fuze wont work with home stereo
The Sansa doesn't play music through the USB port. You can connect the Sansa to your stereo via the Sansa's headphone jack.
Feb 22, 2009 | SanDisk Sansa e250 MP3 Player
Carolla stereo wont turn on..
Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
Cheers.
Nov 09, 2008 | 2004 Toyota Corolla
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
RCA RS2635 CD Shelf System Logo
117 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
