SOURCE: High Pitched wine when turning on
yes it is worth fixing & not that serious. but please call skilled tech to fix it as high voltade is inside even it is off.if you are not a tech person.
SOURCE: TV will not power on
The MZ73L is a posistor, its basically 2 thermal resistors back to back. One is connected across the mains, the other one connects the deguassing loop to the mains. When the TV is 1st turned on the mains connected R is cold so its neighbour is cold, that allows a large surge of current into the degaussing coil. The mains connected one rapidly gets hot and heats up the other one, this increases the resistance of it and the current being dumped into the degauss coil fades away. As the 1st one is a heater it will get hot and you will see signs of heat on the PCB, BUT its still a very good place to start. The heat is normal, but if the 1st ceramic disk in it has died then you will short the mains and blow the fuse with it.
SOURCE: Powers on. green light flashes then turns back off.
For troubleshooting your lamp, use the following lamp troubleshooting wizard here:
http://www.fixyourdlp.com/wizard/launch-window.html
If it turns out you need a lamp, you can follow the simple instructions available here for just about any make and model, including your RCA. The RCA website is useless and they never have parts in stock.
http://guides.fixyourdlp.com/guides.php
SOURCE: TV turns its self on and off
Greetings. I had the same problem with my 29" RCA, and it was easy to repair. I opened the back cover of my tv and just disconected the two wires cable that connect with the upper controler (volume, chanels, etc); and now it is working OK; but I must operate the tv only with the remote controler.
I hope this could help you.
German.
SOURCE: Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
