Question about Palm Treo 500 Centro
Turns on then freezes
The on-off button doesn't work all together. What I have been doing is removing the battery then putting it back in. What happens then is, the phone turns on, the palm logo appears... And then it FREEZES. Any solution? Please?!
    Scholar:
  • 59 Answers
You may have to do a hard reset on your phone if you haven't already. This will erase everything that has been placed on your device since you have had it--contacts, pictures, videos, texts, emails, etc. It is important that all of your information is backed up to the computer by Hotsyncing your device. If you have not Hotsynced your device recently then you will lose all your information, but since it only goes to the Logo you may have already lost your information. I have a Treo and that happened to my device.
To do a hard reset:
  • Press and hold the on/off button while taking the battery out of the phone (DO NOT let go of the On/Off button while taking the battery out and do not release even after the battery is out).
  • Count to ten and then while still holding the on/off button put the battery back in (DO NOT let go of the On/Off button)
  • The phone should power up and show the Palm logo and at the bottom of the screen the black bar should keep getting longer until it reaches the other side of the screen. The screen should change and say "Access Powered" and then go back to the Palm Logo and that black bar at the bottom of the screen should get longer again.
  • If the phone doesnt show "Access Powered" and stays on the Palm Logo screen, then make sure that the black bar is as long as it can be and then release your finger from the on/off button.
  • There should be another screen that comes up and asks "Reset Phone?"
  • At that point you press the UP navigation key to say YES or the DOWN navigation key to say NO. Either one you press, will restart the phone and it should load fine thereafter.
Sometimes the on/off button gets stuck so you might have to play with it a little. If that the button still doesnt work, you need to take it in to a SprintNextel Service Center and speak with a technician who will open the device and test for any physical or liquid damage which could be causing the button to be inoperable.
Posted on Dec 18, 2008
How do i reboot my laptop
The easy answer is to:
For Windows, Click the Start Button, then Click Shutdown and then click the restart option, but this depends on what version of windows. If this doesn't work, please clarify with the version of Windows.
If your laptop is frozen, hold the power button down for several seconds until the laptop turns off. Then click the power button again to turn it back on.
As a last resort, you can remove the battery. Wait 5 or so seconds, re-insert the battery and click the power button to turn it back on.
Jan 23, 2012 | Toshiba Computers & Internet
My phone vibrated and when I looked at it the screen was white i tried turning it off and taking out the battery but the screen is still white.
Try taking the battery out and pressing the power button for 30 seconds to completely discharge it, then put everything back together and try to turn it on. If that doesn't work, there's not much else that you could do unless you have warranty, or get a new phone.
Jul 16, 2011 | Cell Phones
Acer zg5 will not boot
First remove the battery, make sure it is unplug, and press and hold the power button for 30secs. Than put the batty back in and see if it helps. If this doesn't, try removing the hard drive and memory and see if it turns on. If not than the motherboard is dead.
Also, when you say doesn't boot. Does it turn on?
Jul 03, 2011 | Computers & Internet
My T41 no boot, no sounds, only the fan turns on!
The motherboard is most likely damage. First remove the battery, make sure it is unplug, and press and hold the power button for 30secs. Than put the batty back in and see if it helps. If this doesn't, try removing the hard drive and memory and see if it turns on. If not than the motherboard is dead.
Jun 29, 2011 | IBM ThinkPad T41 Notebook
My ti-89 is frozen, no matter what keys i press.and although i took off 4 batteries, but when i put batteries back, it is still same, menu screen.
First try the reset code which is pressing Left-Right-Shift and On at the same time. If that doesn't work you can try removing the batteries and putting them back in while holding the (-) and ) buttons.
If those don't work, there is a back-up battery located under a panel just above the four normal batteries underneath the battery cover. Removing this in addition to the four normal batteries should reset your calculator entirely.
If none of these work then there may be a short in the circuits of your calculator which could have been caused by leaking batteries. In this case you can try disassembling the calculator (being careful to remember how it goes back together) and cleaning the circuit board with circuit cleaner.
Jun 03, 2011 | Texas Instruments TI-89 Calculator
My dsi freezes during the middle of the game. I shut the dsi off and lose my place. I then have to go back to where it was last saved and do part of the game all over again, because I never know when it...
You could try making sure there is no debris in the game cartridge or the compartment by blowing on it, and if it still doesn't work, you will likely have to restore your DS to factory settings. Note that this will delete all of your data.
Remove the battery cover off the back of the unit. (One small Philips screw.)
Remove the battery.
Leave the system without the battery for 10-15 minutes.
Replace the battery.
Re-install the battery cover.
If your DS still doesn't work, you will have to send it into Nintendo and have them take a look at it. If they cannot fix it, they will at least give you a nice discount on a brand new one.
Apr 20, 2011 | Video Game Consoles & Games
Sony Erricsson P1i fell in bath, quickly removed battery, sim, dried by putting it and the battery in a rice bowl. Now wont power up? It does not look like there is any water in it. I removed most of the...
ok, first remove the battery cover and battery and sim leave them in a warm room for 6hours or overnight.
Putting it back together and try it.if it still doesn`t work, try a battery change at your local dealer.
By the way a phone that hasn`t been charged for a while may not show any signs of working until maybe 30 mins.
Nov 19, 2009 | Sony Ericsson P1i
Turns off shortly after turning on
Is this when connected to power source or on battery?
If it is on battery the battery may need to have its memory refreshed.
Turn the 5720 off, remove the battery, hold the on/off button down for 15 seconds and when done put it back together and turn it on.
Good Luck
Apr 22, 2009 | Acer Aspire 5720-6661 Notebook PC
Frozen screen
A friend has an Archos 404, media player, and it foze up while she was using it. Could not power it off or get it to do anything. Ended up having to remove the 4 tiny screws and then Remove the battery. This reset the unit completely. Put it back together, including the battery, and the unit powered on and worked correctly. Often a simple system reset can fix most freezing issues.
Dec 28, 2007 | RCA opal MP3 Player
Palm Treo 500 Centro Logo
309 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
