Question about Plumbing
No heat in three rooms
Steam heat gas three rooms have no heat
  • Joe Neff May 11, 2010
    How old is the boiler? Are they on the 2nd Floor?
  • 15,935 Answers
Zone valves may be sticking. Check for a manual knob to open
Posted on Dec 22, 2008
KitchenAid kdte104dss0 is not drying properly. No steam comes out of side vent. Not sure if there should be steam coming out? It seems to dry somewhat but not completely.
is there any heat coming out of the dryer? If the heating system is not working the dryer will only blow room temp. air and will not dry the cloths.
Aug 02, 2015 | Dryers
What size fresh air vent do I need in a boiler room with a gas boiler and gas hot water heater with about 220,000 btu combined
I suggest that you run a duct that is 3 inches larger than the furnace duct . and you should run it down close to the floor and aim it in the direction of the furnace. this will trap warm air above the vent and supply an adequate supply of air for combustion. also make sure you have insulated any pipes in the furnace room that carry water or steam you want heat where you live, not going up the chimney.
Aug 02, 2014 | Water Heaters
Not enough steam
This may either be because you may not have the correct generator(either the wrong size model or the wrong voltage generator) or the heating element may be damaged, although this would be unlikely being it is a new generator. Go to www.mrsteam.com and size your room. Remember it is important to have the exact room dimensions AS WELL as material of the wall (ceramic, porcelain, natural stone etc) due to the fact that wall material is largely where you have all your heat loss and units have to be sized accordingly to the wall material of your shower otherwise you would surely end up with the wrong size.
Feb 11, 2014 | Mr Steam Ms400e Steam Shower Generator
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
Make : Weil-McLain Model : CG-5-SPDN Series 12 I have the above mentioned boiler which is located on the 1st level of a three story one family house, the area where the boiler is located is insulated.
You don't have an optimum distribution of steam in your house. Try closing a little bit the valves supplying the heaters in the lower floors. Close a little bit more until you get the desired balance.
Nov 06, 2012 | Heating & Cooling
Steam shower no longer puts out steam, only heat.
It is no longer getting water to the unit. Valve closed, filter stopped up, or the float valve is dirty. This is something that must be cleaned regulaly especially if you have hard water. Robert
Jun 13, 2012 | Thermasol Steamshower Generator Classic...
I have a Mr. Steam unit installed in my shower room. When i turn the steamer on it sounds like it is working and the lights are on but no steam coming through!!
Hi I am with Mr. Steam Tech Support please call 1-800-767-8326 and ask for tech support we will also need you model and SN that are located on your steam unit
Nov 27, 2010 | Mr Steam Hardware & Accessories
Whirlpool cabrio wed6200sw0 dryer runs, won't heat up. blows air, lint line is clear and hi limit thermostat and thermal cutoff okay (have continuity) at room temp
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | Whirlpool WED6200S Electric Dryer
My Cozy Heater sized and installed by professional will not heat
I'm assuming your heater is the little Cozy direct vent wall furnace, your room calculations are correct, and at 57 degrees your main burner is constantly on. If so, it sounds as if you have too low a flame which can be caused by a main burner jet with an undersized orifice (like a propane one that got in the wrong assembly line) or obstructed by dirt, inadequate gas pressure, or a main gas valve that is not fully opening.
Open the pilot light inspection door and look at the main burner flame height. If it is less than 2 inches or so, check out the three possibilities above. If the flame is very yellow and wandering around lazily, check the air intake on your vent cap for obstruction.
Jan 31, 2009 | Cozy (W352E) Heater
Thick Cloud of Steam
I would say that the beauty of steam is that it has to get through the 100 degree temperature to leave the aqueous state - i.e. to move from a liquid to a gas.
The benefit of that is that any organizums in the water should be killed as a result of that process. Its possible that it smelt musty or old stagnant water smells but to be honest there is little change of harm to the little ones.
Best wishes
Aug 08, 2008 | Vicks Ultrasonic V5100 Humidifier
Plumbing Logo
51 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
