Question about Polaroid FLM-323B Television
No Picture I have the same problem. You said you replaced 3 capacitors which three did you replace
  • volunteer9 Dec 20, 2008
    I appreciate the info. Sorry about your tv crashing again but I'm going to try this anyway. Let me know how the power board works since that may be my next move. Thanks
  • Anonymous Dec 27, 2008
Well there were the (2) from this original solution:
And I replaced a third that was right by these two. However now my TV has died again. I just bought a new power board and will install tonight (like $120.00). It looks like this is my only option...I'll advise if this fixes our problem. If not I'm chunking it!!!
Posted on Dec 19, 2008
  • hank_wiley Dec 22, 2008
    Just FYI : I installed the new power board and it's working great (for now)
Replaced 3 capacitors for start up issue, now have radom with vertical lines
You will need to replace all the capacitors in the output side of the power supply. It is possible you have other bad capacitors that are not bulging at the tops. The power supply generates a voltage used by the the video processor on the main board. If this voltage is out of whack, it can affect your video. I would recommend you check all power supply voltages for accuracy and ripple.
Jun 18, 2013 | Samsung LN-T4665F 46 in. LCD Television
On SVA model hd4208tiiipdp Indicator light is on but there is no sound or picture.
Is the cables are connected properly. please check to connected any dvd player.
Apr 14, 2008 | Televison & Video
Toshiba cf35d50 audio no video
I would say you have a bad relay or bad capacitor(s) on the circuit board in the TV. There is a high voltage relay that turns power on and off to the picture tube which is probably not functioning.
Apr 03, 2012 | Computers & Internet
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like, buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Jun 02, 2009 | RCA D52W19 52" Rear Projection Television
Lamp come on for 3 seconds than goes out.
Try this: There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Mar 20, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
What capacitor should I use to replace it?
470uf 35v -located on the power main board this capacitor is slightly larger in diamiter than a pencil and about 3/4 of an inch long. there are three of these next to each other. the center one is usualy the bad one but for two bucks each your better off replacing all three.
Aug 11, 2008 | Televison & Video
Polaroid FLM-323B Television Logo
121 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
