Question about Zanussi ZHQ575 Electric Double Oven
I just need to replace the element support for a Kenmore oven, and I can't seem to find it anywhere.
  • aylalei Dec 19, 2008
    No, it's in front on each side of the bake element. It's the support that keeps the element from touching the oven floor.
  • 8,197 Answers
It is behind the control panel.
Posted on Dec 18, 2008
Oven elements aren't heating, Kenmore Range C970-655821
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Kenmore Ovens
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
User_Manuals kenmore c970
Useing a flash light look at the element for bum's or damage if you see damage anywhere on the element turn off the power and replace the element , need help finding the part get back to me with the info and i will locate it for you
Oct 29, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Zanussi ZHQ575 Electric Double Oven Logo
49 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
