Question about Archos Gmini XS202 MP3 Player
Not swich off
Could anybody please tell me,my archos XS202 as had the wrong chager plug in it works ok but will not swich off and the blue light does not come on when i put it on charge can this be, put right or is it no good Please help
  • 705 Answers
Hold down the stop button for 15 seconds to try and force the unit to power off. Then leave it for a couple of days whilst the charge dissipates. Look at the charger you used and compare its output voltage to that of the Archos one. If the voltage is higher than the Archos one it is quite likely that the charge circuit and or the battery may have been adversely affected. If the unit still misbehaves after a few days changes are you will need to have it looked at. If it is in warranty, try a claim, but do not mention you used the wrong charger!
Posted on Jul 26, 2007
SOURCE:
My player is telling me that i need to format the unit even though it's loaded with music files and have had no problems with it in three years. I don't know why this has happened. Please advise..thank you
Somehow the data has gotten corrupted and it can no longer read the contents, or worse, memory failure. You might be able to salvage some of the data by connecting it to a computer and copying the files to the computer. Then, disconnect and let the player format the memory.
Jun 04, 2010 | Archos Gmini XS202 MP3 Player
How to change Archos XS202 battery?
Hi !
I found this site which sells batteries for archos xs202 :
http://www.newmp3technology.com/xs200+batteries.html
Then you have to remove the covers (back and front) of your archos. Then melt the tin that retains the battery cables with a soldering iron.
Then melt the tin again to fix the new battery cables to the motherboard and you're all set. I did it this very morning without problems.
Dec 03, 2009 | Archos Gmini XS202 MP3 Player
Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Dec 17, 2008 | Archos Gmini XS202 MP3 Player
Repairing the GMini XS202
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Oct 21, 2008 | Archos Gmini XS202 MP3 Player
My archos 605 wifi
Try reseting device by inserting a pin in the bottom reset hole. If still non-responsive, try connecting device with usb cable and switch device on then off.
All else fails you have a 1 years warranty on device, which comes standard.
May 26, 2008 | Archos 605 WiFi Digital Media Player
Wrong charger have i killed it or can it be fixed plz help
I ordered the only charger Archos have for my Archos 605. The website listed the charger on the page for accessories for 605 but when it came it said its for the Generation 4 series. I plugged it in and not a lot happens. The green light shows as if it is charging but it isn't. Grrrr
Dec 06, 2007 | Archos AV 500 Digital Media Player
Connect My Archos to my TV
Archos has a site with a video demo on how to connect all leads
Mar 21, 2007 | Archos AV 500 400-Hours Video Recorder
Archos Gmini XS202 MP3 Player Logo
135 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
