The printer wont print and it tells me it is offline and cable unplugged and neither is true?
SOURCE: 1p90 remains offline
i have had a little board inside the machine the connects the usb lead
to the logic board fail and this causes this fault. You will need to
call out a canon service engineer to fix your problem.
if your in the uk i can give you some contacts .
Hope this helps
SOURCE: why isn't my pixma mp145 printer not working?
you have to make sure the correct driver to be installed on the correct OS.. Not sure what OS you are using but below link might be able to help you to get the correct driver.
http://etech.maiila.com/canon-pixma-mp140-driver-manual-software-download-and-troubleshooting-tips
hope this helps
SOURCE: Canon Pixma MP150 offline - won't print from computer
hi,
CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-25
SOURCE: Printer will not print,
Open "Control Panel".
Open "Printers".
Right-mouse-click on your printer.
Click "work online".
HERE IS THE LINK FOR PRINTER IS OFFLINE ISSUE:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#ServiceAndSupport
click on service and support
please Enter Your Question:
type in printer is offline and then search
click on Error: printer is offline
you will have these 5 solutions after clicking on it.
