Question about Dell Latitude D600 Notebook
What did u have in mind
I have control panel up
  • jsylr67 Dec 18, 2008
    i see nothing in here that says qiuck heal is there something i should be looking for
  • 57 Answers
That you go to Add/Remove Programs and try to remove it that way. If that doesnt work I have a method that HP gave me that will also work.
Posted on Dec 18, 2008
  • 3 more comments
  • Andrew
    Andrew Dec 18, 2008
    Ok this is one of my two options since I cannot install the software to give a exact no fail answer for ya:
    1) Open My Computer
    2) Go to Program Files
    3) Look for something called Quick Heal
    4) Open that folder and then look for one of the following files:
    [Note: * 's are Widcards: Meaning anything after or in place of that is fine.]
    unins*.exe, uninst.exe or anything called Uninstall or like it.
    If you see one run it as it will most likely work and remove it for you.
    Also in some rare cases there is a Setup.exe that has the capability of removing the software as well.
    My second option would be to if you can find the Quick Heal folder is to click the folder once to highlight it, Hold Shift and press Delete to permenantly delete it and then go about something that works but I warn you if you do any mistakes can cause issues:
    1) Go to Start > Run
    2) Then type cmd and hit enter.
    3) Once you see the run Dialog type: msconfig
    4) Press Enter
    5) Go to the services tab and uncheck any box that in the manufacturer says Quick Heal in any means or is in the Startup Item Part.
    6) Go to the Services tab and before you do anything check the "Hide all Microsoft services"
    7) Look under Service and Manufacturer for things labeled Quick Heal and uncheck them
    8) Click Apply and then Ok and then then the reboot option.
    This process should manually remove Quick Heal but I suggest you only do this for this program.
    I sincerely hope this helps.
  • Andrew
    Andrew Dec 18, 2008
    Only keep in mind to substitute the Quick Heal for whatever it is your are trying to uninstall.
  • Andrew
    Andrew Dec 18, 2008
    Here is something that should work also... It comes from a removal website.
    http://www.spywareremove.com/removeSpywa...
  • Andrew
    Andrew Dec 18, 2008
    You can also get it removed since its a spyware app from the Yahoo Toolbar since they offer a CA Antispy to help you remove the software.
  • Andrew
    Andrew Dec 18, 2008
    No sorry the Quick Heal was a mistake. That was from a previous solution. However you need to look insteada Quick Heal for Spyware Guard 2008
How do I reset an officejet X476 printer
Keep in mind that these instruction clear everything. The challenge is that if your control panel is locked you may not be able to carry out these instructions. 25371336-krtaiyymi0dz0suct32fia1z-1-0.jpg
Jan 16, 2015 | HP Officejet Pro X476dn Color Inkjet...
Unable to disconnect existing wire on control panel
These white wires could be a thermistor which is a type of heat sensor, if you damage it you have no safety cutout or automatic reset.
Mar 29, 2014 | GE JTP30DPCC 30" Built In Single Wall Oven...
Charter cable remote code
Lacking way to much information I presume you are typing about a universal remote control I might be out of my mind here but I am not a mind reader who made your universal remote control?
Terry
Oct 03, 2013 | Sanyo DP26649 26 in. TV
What to do if your machine atand on control lock
The following link explains how to correct a Control Lock problem on a Whirlpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Keep in mind, control panel features can differ between models. However, the instructions on how to lock/unlock the control panel are printed on the front panel of these washers and are printed in the owner's manual.
If these prelimiary measures do not work, you may have a more serious problem than a simple operator intervention.
If you have questions, or need further assistance, please let me know. I hope this helps you.
Sep 03, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore elite he 4t. Controls are locked! Tried unppluging still the "controls locked". ARGHH! What to do???
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
Aug 31, 2009 | Kenmore Elite 45986 Front Load Washer
Front panel light indicator says "control locked"
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have control lock on whirlpool washer model number ghw9300pw2
Aug 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock on
The following link explains how to correct a Control Lock problem for your washer:
Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dell Latitude D600 Notebook Logo
20 people viewed this question
Alun Cox
