Question about Philips HTS3450 System
My mom just bought this philips sound system and the subwoofer is not producing any sound. The other speakers work just fine but the sub woofer does not work. I was wondering if their was any call backs or maybe some wiring to look for that might be the problem. The number of the product as read on the user manuel is HTS3544 and HTS3555.
  • 8,596 Answers
Press the surround button on the Philips remote to see if the subwoofer will begin producing noise - the surround button switches the mode from simple stereo to full surround. I would test the surround button while watching a DVD, because not every tv channel is going to even produce surround effects. Good luck!
-Tha Mp3 Doctor
Posted on Dec 31, 2008
What is a sound bar woofer and function
A woofer is a device that producers low frequency bass sounds. Often in a form of Sub Woofer. Bass sounds are not directional. So once set up it will give the rumble and vibration needed to the sound system.
Dec 27, 2016 | Audio Players & Recorders
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
SPEAKERS WORK, WOOFER DOES NOT
as far as i know these speakers contain the and everything else in the subwoofer. The good news is that the system itself works, as the speakers produce sounds. If you feel like taking the system apart yourself , you may check for some wires that got de-attached from the subwoofer, if not, i would advise you to take the system to check it by technical support.
Jan 18, 2014 | Boston Acoustics BA745 Computer Speakers
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
HI I BOUGHT HT-S6300 3D-Ready Home Theater System 2 DAYS BEFORE. MY SUB-WOOFER IS NOT WORKING. NO SOUND IS COMING OUT EVEN BLUE LIGHT IS ON. I HAVE CHECKED SPEAKER CONFIGURATION, AND IT GIVES SOUND TO ALL...
Check your owners manual.You will probably have to activate the sub woofer outlet,using the remote.This outlet can usually be programmed to do more than one function.
Jun 18, 2011 | Onkyo Audio Players & Recorders
Surround sound system is not producing sound through the subwoofe
Several things could cause this, to make sure the sub woofer is working at all disconnect the cable from the back of the receiver. You should hear some sort of output from the subwoofer when you handle the plug. IF so replace the plud and go into your settings menu (press the A and B button at the same time) and go through the speaker set up. It may be that the receiver has not retained the memory that there is a sub woofer connected.
I hope this helps.
Feb 24, 2009 | Panasonic SA-HE90 Receiver
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Philips HTS3450 System Logo
319 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
