Question about Samsung SC-D67 Mini DV Digital Camcorder
Distorted sound on playback, samsung mini dv camcorder.
I have a Samsung mini dv camcorder, and on playback the sound is very distorted where words cannot even be understood. The picture quality is fine. This is my 3rd camcorder, and I have 14 tapes, all are distorted, with the exception of the one that is in the unit now. The tape is half recorded on, and when I rewind and playback, the sound is ok.
Even the tapes recorded on previous units (Panasonic and Canon), are distorted when played back on this unit.
  • Samsung Master
  • 2,794 Answers
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Posted on Dec 18, 2008
Samsung SC D363 camcorder displays green wide lines on playback function what is wrong?
Sounds like dirty video heads which is going to require a mini dv cleaning tape to clean the heads and the tape path. Worst case scenario if cleaning doesnt help is that it may need the video heads replaced. I hope this helps.
Sep 15, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
I have a Samsung camcorder and when I play mini dv tape recordings from Canon camera I recorded on , the sound is distorted
If the tape plays correctly in the Canon camcorder, here are a couple of possible reasons for the issues you are having:
1. the Samsung camcorder has a cleaning issue - try running a dry head cleaning tape for about 5 to 10 seconds and see if that helps.
2. The alignment is off between the two different camcorders. Nothing you personally can do about that, but a repair center would be able to correctly align the tape path on both camcorders.
Do the tapes that you record on the Samsung have issues when you play them back on the Samsung? If so, you have a problem with that camcorder (may be cleaning, but could be a mechanism problem) Hope this has helped you. www.austintelstarservices.com
Aug 30, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
I have a samsung scd103 digital cam and when i record something it looks good on the screen while im recording it but when i play it back there are grey lines and distorted sound
Have you tried cleaning the recording heads? Use a dry type cassette cleaner only. It's just like a vcr head cleaner tape, only in the small mini-dv tape size.
Sep 30, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
No sound on my samsung
if you put a old tape in that has sound in it and it does not playback sound then your internal speaker is bad. easy fix and not to much.
Mar 12, 2009 | Samsung VP-D80 Mini DV Digital Camcorder
My samsung mini DV camera SC-D372 keeps flashing "Protection" on the playback screen
turn the camcorder off, take out the tape, look for the protection tab on the side of the tape and switch it to the other side.
protection is a feature of your tape to keep you from taping over important videos saved in your tape
Mar 02, 2009 | Samsung SC-D372 Camcorder
Samsung 800x Digital Zoom Mini DV Digital-Cam
try a cleaning cassette.. if it dont work it is the heads that are bad.. try a good one.. sometimes this happens if u use old mini dv tapes.. try new.. hope this helps ya
May 29, 2008 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung Mini DV camcorder (Protection-Problem)
SOUNDS LIKE THE TAPE TRANSPORT IS BAD. IT WILL EAT YOUR TAPE SOON. YOU WILL NEED A NEW TRANSPORT OR A NEW CAMCORDER ...SORRY
Dec 14, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung sc-d353 blurry now black
Problem is fixable and not expensive either : CCD sensor is faulty and needs replacing.You do have a case for having this problem sorted out by Samsung agent free of charge because the sensor should last 10 years +.
Sep 04, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
SCD23 LCD screen tiles and so does the video upon playback.
Sonys jvc's samsungs all have their ccd imager problems, In your model however I have seen the connector on the ccd board detach itself from the pcb and just needs to be soldered back down.
May 17, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Even after using head cleaner, no playback
SOUNDS LIKE YOUR MAIN BOARD IS GOING OUT. NEED TO SEND IN FOR REPAIR
Feb 01, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D67 Mini DV Digital Camcorder Logo
286 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
