Question about Hotpoint Washing Machines
Can you please tell me where we locate the Pressure Switch for a hotpoint ultima wt741 machine - i have read that f05 can indicate a problem with it and we want to try and check it before calling an engineer
  • Hotpoint Master
  • 3,463 Answers
The preswsure switch is to be found at the top right front corner of the m/c.
It can be identifiefd by a plastic tube about 5mm in diameter going to it.
Before changing it ,make sure that the pump is working o/k as this can lead to the problem you are experiencing.
Plz rate my solution.
Thanks.
Posted on Dec 18, 2008
My machine is not draining and f05 is displayed
Hi.
F05 means that there is a drain problem. Either rain cannot completer or the pressure switch detects that machine is full.
Disconnect power and empty water accessing the drain filter, which is usually located at the front bottom side of the appliance, behind a kick panel on the right. If the problem comes back test the machine with the drain hose at the back going on a bucket, low near the floor. Drain hose may be blocked or may use incorrect height settings (check manual). If F05 is prompted when there is no water, then the problem is the pressure switch located in control panel. Clean the long thin hose connected to pressure switch. If that does not work, then replace pressure switch.
Regards.
Ginko
May 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
Comes up in the display f05
F05 means pressure switch jammed on full.
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic fillter inside hose.
Reassemble and test.
Dec 21, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima washing machine showing fault code f-05 and door will not open.
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Locate and remove large black hose fastened to bottom of drum.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Thanks
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima wt741
Hi.
F05 meqans that pressure switch is jammed.
You will neeed to call an engineer.
Jun 12, 2008 | Hotpoint WMA35 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
175 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
