Question about Refrigerators
Sub Zero model # 695 is flashing EC-40 error message. No ice.
I know the error code means the freezer compressor is running longer than normal. I have cleaned the condenser what else could be wrong. Is it something I can fix myself.
When our Sub-Zero Model 650 quit making ice, and the SERVICE ICE lights started flashing, we called our technician who said, "You can pay me $178 for a service call or have another option - you have 2 seconds to decide. Oops, your time is up, I will decide for you!"
"Open the door and push the REFRIGERATOR UNIT ON / OFF message button; wait 30 seconds and push it again. About 95% of the time, the unit creates the glitch, and you are simply rebooting the computer. If that doesn't work, call me. I hate to take your money to come out to push a button."
IT WORKED! The warning message turned off and the freezer started cranking out ice.
Posted on Sep 24, 2014
Master_Tech
  • 770 Answers
SOURCE: sub-zero 650 vacuum condenser light keeps comming on
1st is the Condensrer clean?? if so has the light been reset ??? need to know how ask... the pressures will vary depending on the coil temps if you reset the light and it comes back within a day or two and the coil is clean.. It is a long run time error given from the compressor
Posted on Jan 29, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
  • 56 Answers
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
wheelshot
  • 102 Answers
SOURCE: 650 sub zero that has a vacuum condenser message returns.
I have seen this many times and have fixed the problem many times. You may notice a ball of frost or ice build up in the fresh food compartment, This is because you have a leak in your evaporator coil and it needs to be replaced. It is a pretty costly repair but well worth it in consideration to what you paid for this unit or what the cost of a new one would be. Because it has less freon in it is why the compressor is running longer and causing message to pop up. Have the evaporator replaced in the section that is giving the issue and this will solve your problem with the unit.
Posted on Apr 11, 2009
Chadha Saab
  • 142 Answers
SOURCE: vacuum condenser light of sub zero 650 is on - how to clean it
We recommend vacuuming your condenser every 3 - 6 months. Cleaning the condenser is important for the overall operations of the unit including cooling functions. A dirty condenser may lead to warm temperatures in the refrigerator and freezer. It may also cause the unit to run excessively. It may contribute to condensation or frost inside of the compartments. If the condenser is not cleaned properly it may even cause premature failure of mechanical components in the unit. Condenser Cleaning - All Models Before cleaning the unit, shut the electricity off at the control panel. When you clean the condenser, wear gloves to avoid injury from the sharp condenser fins. Use a soft bristle brush and vacuum to remove dust and lint from the condenser. To avoid bending the condenser fins, be sure to vacuum in the direction of the fins, up and down. Clean the condenser every three to six months or sooner if you have pets. 600 Series Framed and Stainless Steel louvered grilles: First remove the grille screws located at the bottom of the grille. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. Overlay Panel Grille: To remove, lift up then pull out at the bottom and down to release from its mounting bracket. Remove the two black screws in the lowest louver of the grille. Tilt the bottom of the grille out and away. It will release from the top of the grille. Model 601RG Stainless Steel Grille: Remove in a similar fashion as the overlay grille panel. 700 Series All Units: At the bottom of the unit, remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 400 Series 424/424FS At the bottom of the unit, remove the screws holding the kick plate. The condenser is located behind. 427/427R: Remove the four screws holding the kick plate/grille in place. It will then slide forward, giving you access to the condenser area. 430: First remove the screws located at the bottom of the grille. NOTE: These screws (Phillips head) are accessed with the door open. Tilt the top of the grille forward and release the springs from behind the grille, then lift off. 200 Series 245, 249, 315W Remove the kick plate at the bottom of the unit, giving you access to the condenser area.
Posted on May 30, 2009
Sub Zero 642 side by side, refrigerator side not working.
If the refrigerator compressor runs and cools when you use the manual activation mode but does not run normally then the control board would be what I would suspect. If it has the manual activation then it is new enough to give error codes. If it is not running and not recognizing it's not running, something is wrong with the control. Unless you are seeing two dashes in the refr display. That would mean the refr section was disabled.
Jan 11, 2016 | Sub-Zero 642
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Refrigerators
Compressor kicks/clicks out after approx 10 sec run time,fan runs normal,not froze up, freezer barely cools,negative frig, happened overnight to 6 yr old unit
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Refrigerators
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
My side by side refrigerator no freezer and no cold condenser fan and evaporator fan are running but compressor normal no warmer,no hot
heatman101
Apr 16, 2011 | Kenmore 55602 / 55604 / 5560 / 655609 Side...
My 632 is flashing EC 40. What is the problem?
Here's a list of all error codes for the 600-series Sub-Zeros.
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
EC40 = Excessive Freezer Compressor Run
Mar 24, 2011 | Sub-Zero 632 / S
I have a Kenmore fridge model 53542300 the fridge and freezer are not cooling I can not hear compressor running nor is it hot. I do see the fans running for Fridge and freezer. I went to check the start...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 28, 2010 | Kenmore Refrigerators
MY frig is only 1 month old. Model# GTH18DBXCRWW. It has started running louder than usual and seems to run longer. I misplaced the manual and need to know what the problem could be.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | GE Refrigerators
My freezer is working fan is running., dont know if it is running to capacity or not; items still frozen, my refrigerator is not working most items are warm so i know it has not been working for a while...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 15, 2010 | Amana A9RXNMFWB (190 cu ft) Top Freezer...
WE have a fan constantly blowing over the coils is this normal
It is not normal if there is less traffic - in and out of the fridge or freezer - if all is ok.
At night it should run less. You have 1 condenser fan to service both freezer and fridge compressors, which run independent of each other though they both regulate the condenser fun.
If you you have a dirt condenser coil (on to of the appliance), the cooling effect reduces, causing the compressors run longer till the meet the cabinet set temperature. Every time a compressor runs, the condenser fun runs.
If you have less traffic and have a clean coil, then call a service tech.
Nov 07, 2009 | Sub-Zero 661/F Side by Side Refrigerator
Refrigerators Logo
1,451 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
