Question about Whirlpool Dishwashers
Dishwasher locked key has been activated.
Some how I accidently locked the key pad on my dishwasher and I don't know how to unlock it. The style is a quyiet partner II. Please advise.
  • stapril Dec 23, 2008
    I am having the same problem, but I do not have a "heat dry"...I have pushed in the "air dry" button for 5 seconds (which on the panel it says to do) but still nothing!!! HELP!!!!!!
  • 8,197 Answers
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Posted on Dec 18, 2008
Dishwasher wont turn on when I press start and... the "3 second" lock light is constantly on??
Child Lock Controls
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock the
dishwasher controls by pressing and releasing the RINSE
ONLY pad (some models) or the NO HEAT DRY pad (some
models) for 3 seconds while the door is latched. An
indicator light on the lock graphic pad will illuminate when
the controls are locked and no new selections can be made
until the lock is released. To unlock the controls, press the
same pad, RINSE ONLY or NO HEAT DRY, again for 2
seoncds until the indicator light goes out.
Hope this helps?
Mar 31, 2016 | Frigidaire FFBD2406NW Built-In Dishwasher...
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
My dishwasher syas it is locked and i don't know how to unlock it
Press and hold HEATED DRY for 4 seconds. The light turns off.
Here is the manual for your series of dishwasher
Link:
Mar 07, 2012 | Whirlpool 24 in. DU1055XTPS Stainless...
I have a model KUDV245EWHY the key pad has a code to child unlock it..touch key pad..
I think you want to disable the childlock key. I think all you need to do is press the child lock key for 5-6 secs .That should disable the child lock.
Jun 01, 2011 | KitchenAid 34 in. KUDV24SE Built-in...
The lock symbol light is on and the dishwasher won't start
the dishwasher controls by pressing and releasing
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
when the controls are locked and no new
selections can be made until the lock is released.
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
I need to unlock my ge profile pdw9200jcc dishwasher
To unlock the dishwasher controls, press and hold the HEATED DRY pad for 3 seconds.
The light above the lock pad will turn off. To lock the dishwasher, press and hold the
HEATED DRY pad for 3 seconds. The light above the LOCK pad will turn on.
If you need a replacement manual you can get one on the link below.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-55015.PDF
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | GE Kitchen Ranges
Dishwasher will not start
You have a clean light flashing. You need to reset you control. It is activated by a number of different situations. Find the tech sheet for your dishwasher which is normally located under the bottom plate of the dishwasher. If you can not find it give me the model number and I will tell you how to activate the diagnostic test. If you do find it follow the section that says diagnostic test. Then check and makes sure you heater element is operating.
Feb 23, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore ultra wash dishwasher
More than likely it is a shorted key. replace the touch panel.
Dec 04, 2008 | Kenmore Dishwashers
Dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Jan 20, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Dishwashers Logo
743 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
