Question about JVC RX-8010V Receiver
Switches Source input on its own
I have a JVC RX801v amplifier. The problem is that it changes input sources on it's own. Sometimes it is a constant annoyance, other times it will go for hours and be OK. Usually I am using it in the TV/DBS mode and it will most frequently switch to DVD and sometimes VCR mode....without any input. I even tried putting black tape over the infrared receiver on the amp to insure it wasn't getting any spurious remote commands, but it would switch anyway. Thanks!
  • 277 Answers
SOURCE: not getting digital sound from dbs or dvd
try all the possibilitys of connecting cables between the outputs & inputs exept the ones that r allready working maybe theres a wrong connection inside the reciver windman
Posted on Jan 31, 2006
  • 4234 Answers
SOURCE: sound cut-out
Most likely this unit goes into protect mode due to heat detection. Try to see if there is a pattern to when this behavior starts. Does a lower volume level allow the unit to run longer? Perhaps there is a problem internally that is allowing DC voltage to get to the output stage. This will cause excessive heat which can then cause the protection circuit to kick in. This unit may need to see a bench with some test gear to locate the exact problem. If you can, look for any pattern and update this.
Dan
Posted on May 13, 2008
SOURCE: JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Posted on Jun 22, 2008
SOURCE: JVC RX-9010V - Setting up Digital Inputs
Just to the left of the volume is a "settings" button. Press it and cycle through the options until you reach "Digital Coax," then use the "Control" up and down buttons to change the assigned source.
Posted on Jul 04, 2008
  • 336 Answers
SOURCE: JVC RX-9010VBK receiver - premap section won't turn on normally
It sound like a bad connection. The first thing that I would do is tighten all the ground screws that hold the circiut boards and the heat sink to the chassis. If that doen't fix it, flex the circuit boards slighty to see if the relays chick on and off (disconnect the speakers first). It could be on the input board, on the relays themselves or just about anywhere.
Posted on Feb 01, 2009
Russound CA6.4 amp / controller - 3 of the 6 zones can't switch source inputs.
I suspect the inputs will all go into an IC. You just need to trace one of them back till you come across it. Either the circuit around it will be the problem, or more likely the IC itself.
Jul 01, 2014 | Russound CA64IL Amplifier
Sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
Jun 18, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My unit returns to demo mode everytime I restart my Chevy s-10 and I loos all the presets and clock settings
Make sure the yellow wire is going to a source that has 12v going to it when the key is turned off. The yellow wire controls the memory and needs a constant voltage source.
Sep 15, 2011 | JVC Car Audio & Video
It says "Source Direct" and
I think that your receiver might be set to the wrong input. Try to change the input to "tuner" and you should be able to hear the FM radio. To change the input, all you need to do is press the button labled either source or input
Jan 07, 2011 | Kenwood Audio Players & Recorders
DVD player re-sets with ignition
either bad ground at headunit or you don't have tha yellow 12+ constant wire on the jvc hooked to an actual 12+ source maybe it is not a source that is capable of the amount of current that jvc needs
Mar 15, 2010 | Car Audio & Video
Sound output problems
Are you saying a stereo source sometime switches to multichannel? In my experience, that's the opposite of what I think could be happening.
Many AVR's have automation that can be set to select the better of the two audio paths from a source if you have analog and digital assigned to the same input. If digital is present, it prefers it. If the signal degrades or goes away, it switches to analog. I think it's trying to tell you the hdmi cable connection or the source is flaky.
Perhaps you could flesh out the details of what input is being used and also look at the source device. Isolate the cause by swapping it to another compatible input and/or trying another cable.
Feb 11, 2010 | Audio Players & Recorders
TV does not turn on, it only makes a ticking noise.
Sometimes the input, or source has been changed without your knowledge. Try to change the input button either through the remote, or directly on the monitor. This should rotate you between the snow screen, cable and another input screen. One of them should be moer than just the black screen you see.
Jul 05, 2009 | JVC LT-47P789 47 in. LCD HDTV
Amp neon lights wont turn off
There are two types of power that feed your amplifier. There is a constant power that connects directly to the battery and there's a remote power that usually connects to the remote power output of your deck. Some decks do not have the remote power output, but they have a power antenna output that works just as well.
The remote power is what enables the amplifier to turn off when the car's power turns off.
Either way, it sounds like you have the remote power input on the amp connected to your constant power source.
That would prevent the light from turning off with the car.
If you don't have a remote power or power antenna output on your deck, I would invest in a new one.
However, it is relatively easy to find a remote and a constant power source in your fuse box.
Purchase a fuse tap for a few cents and connect the remote power input on the amp to a power source in the fuse box that turns on and off with the ignition.
Some of the power sources you can find in your fuse box that go on and off with the ignition may be labeled something similar to the following:
ignition, power windows, radio, accessory, etc.
The constant power sources in your fuse box are the ones that don't power off with the car, such as the dome/interior light, power locks, battery, etc.
I hope that some of this helps out a little.
Dec 04, 2008 | Car Audio & Video
Input source switches automatically on my receiver
sounds like a short in the receiver itself.
definitely an electrical problem.
Feb 09, 2008 | Pioneer VSX-D514 Receiver
No sound output from amp.
It has bad parts. It should NOT be drawing 15amps at idle!! You need to grab a DMM and check the mosfets!!
Sep 20, 2006 | Rockford Fosgate Punch 800a2 Car Audio...
JVC RX-8010V Receiver Logo
56 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
