The boot code for the recovery partition(PQService; EISA) has been set to 00. Now it doesn't boot when I press F-11 during bootup. 80 is for the normal boot device. It worked once, But I lost the partition info during reinstall. Active partition restored my drives, except for the boot codes. I could experiment with different numbers. I have verified that the recovery partition is still there, and all the files too. If I change it to the active partition, it will boot. I am using Symantec system recovery disk, and partition table editor. Also, every time I use the disk, drive d: becomes hidden, and I have to reset it to TYPE 07, not 17. hope you can help THANKS Dave Mosher
SOURCE: emachines t5212 system restore backup files, please help!!
If you only your files to be copied in the other or any storage disk then you can remove the hard disk of your machine and then attached it to the other functional machine. in there you can browse and copy all the important files. after copying all your files then you can take back the hard drive to your non functional machine and then install new operating system. documentation found here: http://support.microsoft.com/kb/316941
tell me if something wrong with your system when applying the solution.
melnavz
SOURCE: emachine t5026 boots only with os disk in drive
Emachines don't use the cable select properties very well. Change your drive to Master, reformat and reinstall the operatiing system.
SOURCE: Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Testimonial: "Highly knowledgeable and an awesome guy for taking his time to share his expertise with the pc community. Thanks again!!!"
