Ran fine since last spring's work. Shut off to listen to wife. Would not restart (lawn tractor). Tries but backfires.
It could be as simple as a sheared flywheel key and/or the valves needing adjustment. The OHV engines that come in lawn and garden equipment these days are notorious for being very picky about the correct valve settings, especially single cylinder engines. Another common problem involves the fuel inlet valve in the carburetor. Not the solenoid valve but the float valve inside - if it doesn't seat properly fuel will overflow the carburetor and enter the engine. Several bad things happen after that - the cylinder can get enough gasoline in it to lock the piston when you try to start it and that can result in the aforementioned sheared flywheel key. The gasoline will also get past the piston and into the crankcase where it dilutes the oil and the result is poor lubrication. one of the first components to suffer from the lack of lubrication is the camshaft, particularly the exhaust valve lobe, which wears down to the point that it does not open the exhaust valve far enough and the exhaust cannot be expelled fully on the exhaust stroke. The leftover gasses then escape from the engine through the carburetor when the intake valve opens, sounding like a backfire but rather than fire coming out the carb you get popping and raw gas blowing out the intake. Check your oil for the odor of fuel. If it smells like gasoline and, perhaps is inexplicably overfilled with oil according to the dipstick, plan on having the carburetor inlet needle and seat replaced, possibly the flywheel key replaced and probably the camshaft replaced. Keep your fingers crossed that it is just the valves needing adjustment.
Remember the acronym KISS with all due respect (keep it simple stupid) as a long time turf equipment technician I and my coworkers always try to comlicate matters when usually the awnser is simple. I would recommed you start with the spark plug! I have seen spark plugs cause some very unusual syptoms.
SOURCE: 19.5 HP brggs engine (craftsman) shuts down after long runs.
Sounds like the coil,pull the shutoff wire off the coil and try it.if you still dont have spark replace coil.
SOURCE: Craftsman 15.5 lawn tractor (917.271061) won't start
Here is a link to the manual wiring schematics on page 31
Please rate this a fixya
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
SOURCE: craftsman lawn tractor 917.271060w/kohler 15.5 hp
15.5 hp engine stops running and now will not start. when trying to start the engine it back fires through the carb.
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
