Question about Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load will not pump water out
I have a Bosch WFMC 3200 that will not pump out water. It beeped and flashed ER04 we took the front cover off, drained the water out, checked for debris, did not find anything. Tried putting washer on drain makes a humming noise. Tried putting it on spin makes same noise and will not pump out water.
  • 1 more comment
  • Anonymous Feb 19, 2009
    I also have a WFMC 3200 front load washer. Same issue, it alarmed, I checked the drain hose for blockage and unpluged. Then when I switched to drain or spin it sounds as if a relay is stuck. I know the machine drum turns in other cycles, but drain and spin are not working. I was hoping it was a reset.
  • Anonymous Mar 16, 2014
    replace pump in 3200 bosch frontload washer
    wfmc 3200 how to remove pump
The pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Posted on Jan 01, 2009
I HAVE A BOSCH FRONT LOAD WASH MACHINE MODEL WFMC3200UC. IT WILL FILL AND THE LIGHT COME ON TO WASH AND THEN IT STARTS PUMPING OUT THE WATER.
B This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 02, 2011 | Bosch WFMC 3200 Front Load Washer
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
Jun 07, 2011 | Bosch WFMC 3200 Front Load Washer
How do I replace cold water solenoid on Bosch WFMC 3200 washer...take off top or access from back panel?
take off the top and u will see the solinoid in front of you. just be sure to turn off the power and water b4 replacing.
Jan 02, 2011 | Bosch WFMC 3200 Front Load Washer
Error code F03 flashing and beeping
hello,
what this error F03 code mean is an indication of over flow of water from the sensor reader temperature which might cost a chance of loose wire connection on the water temperature.
what you are to do to fix up the problem is to open (unscrew) the washer and then fix up the wire that have loose it position then clean up all liquid around the wire and the panel and (screen).then couple it pack make sure all power supply are OFF before doing this .
thank you.
Jun 12, 2010 | Bosch WFMC 3200 Front Load Washer
It won't drain and spin
if the drain tube from the washer to the pump and the pump to the house drain is plugged or kinked,and the water can't drain the pump will have back pressure and the e.c,u, will shut off the pump, if the water can't drain then it will not go into spin,also check the pump for blockage or a broken impeller
May 11, 2010 | Bosch WFMC 3200 Front Load Washer
Unable to open door
You will have to pop off the panel on the bottom right of the front of the machine. Inside you find the pump. You will have to make the pump work manually (Look out for the flood.) Once you have drained the water, then the door should open.
Jan 10, 2010 | Bosch WFMC 3200 Front Load Washer
Need the process to remove pump from bosch wfmc 3200 washer?
Do a Internet search and type in the model and diagram.
Nov 19, 2009 | Bosch WFMC 3200 Front Load Washer
Wfmc 3200 fixed E04 problem, where does the gasket go?
Take the cap back off. Put some pipe thread sealent on it. Just some basic pipe thread tape should do the job.
Feb 13, 2009 | Bosch WFMC 3200 Front Load Washer
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
427 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
