Question about JVC KD-S640 CD Player
JVC KD-S640 pinout needed
I have a JVC KD-S640 CD player I would like to use but the rear connector is missing and there is no pinout info on the unit, my thought was to solder wires directly to the pins making my own pigtail, anybody have the pinout info they could share? thanx
  • Gene Rogers Apr 01, 2007
    thanx, good solutions
    Scholar:
  • 135 Answers
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
CD's are being ejected without play (JVC KD-s640)
Take a torch and see if there are any foreign objects in the loading compartment. Children are know to insert for coins to just about anything they can squeeze through the ****.
Then try removing the system from the dash and open the top lid. see if you can clean the lens from a small cutout on the loading mechanism using a cotton ear bud. Do it in good light because the lens ( looks like a fish eye ) can oly been seen at an angle through the cutout.
Mar 08, 2011 | JVC KD-S640 CD Player
I need to know how to troubleshoot an err4 code and what it means
hold the reset button with a pen tip for 20 secons and it should be back to normal
Dec 26, 2009 | JVC KD-S640 CD Player
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
Aug 16, 2009 | JVC KD-S640 CD Player
I want to wire the kd-s640 to my boat. I need to know what wire by color (except black ground) goes where. Thanks. dave.dunklee@gmail.com
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Jun 12, 2009 | JVC KD-S640 CD Player
Just stopped playing
Change the audio amplifier IC maybe are damaged
Oct 30, 2008 | JVC KD-S640 CD Player
Control Panel Replacement for KD-S640
Here is the DIRECT link to buy the parts you need. Copy and paste this link to your browser.
http://www.pacparts.com/model.cfm?CFID=1284915&CFTOKEN=48698629&mfg=JVC&model_id=KDS640&row_start=1&src_model_id=KD-S640&action=list_part
May 30, 2008 | JVC KD-S640 CD Player
JVC KD-S575
Most versions of the JVC KD-S575 uses the 16pin block connector as shown below. It is available at the JVC Accessory Store.
Below image shows the pin's alphanumeric designation.
Color coding and where connected is shown below.
A2 Brown - cellular phone/mute
A4 Yellow - Always on B+12 (such as the battery's positive terminal)
A5 Blue/White - Power Antenna
A7 Red - Accessory or switched +12VDC
A8 Black - Chassis/Ground/GND
B1 Purple - Right Rear +
B2 Purple/Black - Right Rear -
B3 Gray - Right Front +
B4 Gray/Black - Right Front -
B5 White - Left Front +
B6 White/Black - left Front -
B7 Green - Left Rear +
B8 Green/Black - Left Rear -
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | JVC KD-S570 CD Player
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
How do I change the time on the clock??
hit the power button. wait till it says ATT or something like that then hold select then use the volume to change time and up/down to change Minute.Hour.
i had this same problem
Oct 05, 2006 | JVC KD-S640 CD Player
JVC KD-S640 CD Player Logo
1,315 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
