If you have a launcher that you down loaded from store on your pad, take it of, if not reset, last thing plug it in your pc and run an update or back up if you have one. If that don't help put new firmware on that will work with your device.
I don't think you can do that because it is the Samsung built-in/default launcher and it comes pre-loaded with your tablet. If you don't like it (I assume that's why you would want to get rid of it), install other app launchers, such as Apex Launcher, Nova Launcher, etc. from the Play Store and use any of those as your app launcher.
It looks like the Huawei launcher is failing to load. The launcher is basically Huawei's personal skin for your launcher. As to why it's crashing, I'm curious if you've flashed it with a custom rom or anything. Otherwise, the best thing to do is to go into settings, and reset the phone to manufacturers default.
This will erase everything on your phone, so make sure to back-up any files you want to keep, like pictures or recordings.
Try Reload (Aim Off-Screen press B button). Possible that your Rocket Launcher is not loaded?
Also remember, the Zeus has to be aimed at a target for three long seconds before it can fire. (due to the fact that it is a target-seeking rocket launcher)
ffirstly check out that the software which you are trying to install is compatible to your O.S. or not. It seems that it may be the compatibility issure.Get fesh copy of upgraded NCsoft launcher and then again try to install it.
I think it was a case of not enough drive letters so the drive was never mounted once i gave the drive a logical address it worked. Go through advance admin settings in windows and check drive status,
Try double checking your drainage hose depth. We just put ours all the way in, and our machine would shut off. As sson as we put it at reccomended depth, no problem!!
