Question about Aiwa NSXAJ70 Mini System Dual Cassette Shelf System
Cancelling timer play altogether in AIWA NSXAJ70
Somebdy set up the timer play in this machine, and it starts playing cd at odd hours. I tried to use the timer button to cancel the timer play without any success. I could change the play time or change from cd to FM but could not get rid of the timer setting altogether. In alarm clocks they have a on-off button, is there anything like that in this stereo system?
DP
  • 1 more comment
  • paul0005 Dec 19, 2008
    I read the manual in this website and tried to fix the problem by pressing the timer button, then changed the time when the play will start. So that there is no play at all should I change the duration to 00 in the next step?
    DP
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    No, simply cancel timer operation.
    Do you have user manual of Aiwa NSX-AJ70
    How to disable / enable timer option is available in it.
SOURCE: HOME STEREO SYSTEM CD PLAYER
aiwa cx-na508
Posted on Jul 28, 2008
SOURCE: aiwa 3 disk CX-NMT 70 MODEL SPINS A FEW TIMES ON EACH DISC..wont play at all..What can I do? Thanks!!
This can be fixed by adjusting the POT on the rear side of the laser. My Aiwa had the same issue and there is an orange screw on the rear of the laser. Turn it about 1/16 - 1/8 turn COUNTER clockwise.
Please understand, this is a temporary fix, and will eventually ruin your laser mechanism completely. The company is out of business and the unit is 10 years old, so I didn't much care...perhaps I will run across a CD assembly I can replace it with, but this is a temporary fix for this issue.
Posted on Dec 26, 2008
ponker
SOURCE: fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Posted on Mar 26, 2009
  • 4234 Answers
SOURCE: I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Posted on Feb 23, 2010
  • 7 Answers
SOURCE: aiwa nsx-999 display and cd changer problems
replace lazer ever 2000 hours the display may have a dry joint on the 18 volt input ps the lazers are all the same in all the nsx moduls
Posted on Mar 23, 2010
Whay does my AIWA CA-DW63OU start playing by itself?
are you sure it's not going into demo mode after you turn it off? Is there just lights and display flashing? - that is demo mode. Probably a button on the remote to turn it off.
May 13, 2014 | Aiwa Audio Players & Recorders
AIWA ED37 WAS SKIPPING WHEN PLAYING CD'S ... NOW WON'T PLAY CD AT ALL. CLEANED LENS AND GOT CD TO PLAY FOR A FEW SECONDS, BUT STOPPED PLAYING AFTER THAT. IS REPAIR POSSIBLE, AND, IF SO, WHERE?
Well, you proved that it is a laser pickup problem, and the only way to fix this is change the whole assembly "costly" or replace the unit "best option"
Jan 16, 2011 | Aiwa CSD-ED37 Boombox
I have an Aiwa stereo cd player that only plays certain cd's but not the new ones, it is model cs-na222
Some Aiwa players will not play burned, non-closed or expanded limit cds (CD of 700MB or overburned to 750MB).
When you say new cds do you mean purchased pressed cds or ones you created?
Jun 03, 2010 | Aiwa Audio Players & Recorders
Copied CDs won't play with my Aiwa LCX 350 shelf system. It will spin for a bit, then stop. I've tried every method ... with or without remote, start/stop, etc. This doesn't happen with any retail CD. Only...
It sounds like it's not reading the CD. 2 things to try, neither of which are guaranteed to work:
1) Try changing the brand/colour of your recordable CD.  Some machines read different colours/brands better than others; particularly older CD players.  If the ones you have are all light-coloured, try burning a couple of dark-coloured CDs and see if that helps
OR:
2) It could be the speed at which you're recording.  Try burning a CD at 1x speed and see if that helps.
May 26, 2010 | Aiwa Audio Players & Recorders
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
My Aiwa cx-nma545 keeps turning off.
Your system is in 'Eco' mode. If you are in this mode, and go 10 minutes without playing a CD or cassette, it will automatically turn itself off.
Here's how you get out of 'Eco' mode:
1) Go to the jog wheel assembly
2) Press 'Eco'
3) Press 'Enter'
4) The display will show "Eco Mode On"
5) Immediately turn the jog wheel, to turn the status from 'On' to 'Off'
Feb 08, 2010 | Aiwa NSX-DS55 CD Shelf System
No Subwoofer sound with pro logic on TXSR503
When you are playing cd,s set your amp to stereo and the sub should work,prologic should never be used for playing music as this destorys the sound stage,if you are useing small speakers make sure you have set the size in the setup menu and the cross over to about 80hertz.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Onkyo TX-SR503 Receiver
Its a NSX S555, but tis old.
Just press TIMER button three times, you'll see 'OFF' on the display and that's it.
I revange - if you already have the manual please send it to fidelw@wp.pl
I also try to play CDs randomly - let me know if you know how to do it
thx
Nov 13, 2007 | Aiwa NSX-DS55 CD Shelf System
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Alarm clock radio feature
Before you do anything else, Cancel the Timer setting, which is activating the machine to start Playing in the afternoon. You will need the machine's Remote for this. On the Remote, Press TIMER repeatedly, while pressing SHIFT, till the Clock Symbol disappears from the Front Display. Now if you have to reset the Timer to play the machine at a different time - early morning, as you desire, follow these steps. First You have to make sure that the clock is set to the correct Time.Is it? Fine. If it is not,read trhe Owner's Manual and set it to the correct Time. Take note that you mark the AM or PM funtion properly. After the time is set correctly, You gotta set the clock to Switch On the set at a designated time in the morning. Follow the "Setting the Timer" instructions in the Manual to do so. Please do make the effort. I am here to help you, but I also do not encourage spoon feeding. You havta to some work yourself too. If you are still unable to do so, mail me at guptapravin@hotmail.com, and I shall send you step - by - step instructions Good Luck!
Sep 19, 2006 | Aiwa NSX-AJ310 Shelf System
Aiwa NSXAJ70 Mini System Dual Cassette Shelf System Logo
52 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
