Question about Sharp AR-M205 Copier
System settings on Sharp AR-M205
I want to change the scanning feature on my Sharp AR-M205 to scan as a .pdf file. How do I get to the System menu on the panel of the copier??
  • Bobbarry Dec 29, 2008
    I want to do the same thing. I end up with multi-paged tif files and would like to convert those to pdf.
    Problem Solver:
  • 13 Answers
You may also want to trying downloading the manual from here:
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
Posted on Dec 14, 2012
    New Friend:
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
Posted on Dec 29, 2008
How can I use Adobe Acrobat 10 to scan with Sharp Copier AR-M205?
From control pannel of your pc ,go to the scanners and camera and see your AR_M205.then dubleclick on it.ok?
Nov 11, 2014 | Sharp AR-M205 Copier
What is the solution of sharp ar m205 - E7 /11 error
E7-11 Shading troble(whifecorrection) IMPRPERCONNECTION OF THE CCD UNIT CABLE DIRT ON THE MIRROR,THE LENS,AND THE REFERANCE WHIT PLATE copy lamp lighting abnormality ccdunit abnormality MCUPWB abnormality (when occurred in the scan position)improper installation of the mirrorunit
Sep 14, 2010 | Sharp AR-M205 Copier
We want to be able to scan from our copier to our
He's wrong, but with all due respect, it's not going to be accomplished by you without the help of someone who knows this product.
Feb 02, 2010 | Sharp AR-M205 Copier
I have a sharp AR-M205 using sharpdesk 2.7 and can only scan from the simplex to a tif file, would like to scan as a pdf file. when i scan 1 document from the platten i can save as a pdf but cannot with...
When you installed the button manager you should be able to go in and change the SC descriptions ex. SC1, SC2 - SC6. When you use the sharp desk to scan you are operating in a pull scan but when you use the SC programs you are using the push scan mode. You can change the SC mode when you put the copier into scan mode.
Oct 09, 2009 | Sharp AR-M205 Copier
When I scan in sharp AR M-205, my scanned copy becomes very small size, so how to set for normal size?
Make sure the default scan setting is not for a TIFF file format. Sharps are notorious for sending very small TIFF scans.
Jun 08, 2009 | Sharp AR-M205 Copier
I need help regarding our scanner. Thanks.
The problem is you don't have enough memory to scan A3 in 600dpi. You can either try lowering the dpi or add additional memory.
May 20, 2009 | Sharp AR-M205 Copier
Error CE while scanning though N/W in Sharp AR M-205
If subcode is 00 then network connection is problem, if 02, then its not talking to the network scanner tool on the computer. Might be an IP address problem, where the address in the webpage of copier is wrong for the PC.
Mar 19, 2009 | Sharp AR-M205 Copier
PRINTER & SCANNER DRIVERS FOR SHARP ARM205
i have need sharp ar-m205 printer software .
Mar 17, 2009 | Sharp Office Equipment & Supplies
Sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Feb 28, 2009 | Sharp AR-M205 Copier
Sharp AR-M205 Copier Logo
393 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
