Question about Dell Latitude D600 Notebook
Is there anyway u can walk me thru getting rid of spywareguard2008 and restarting my computer
Ststem shuts down cant get online
  • Dell Master
  • 19,396 Answers
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing
Posted on May 21, 2009
Cant reboot after failed Windows 10 update. Tried to restart with Gateway Recovery Mgt.program.
Try this:
Start the computer. As soon as the "Starting Windows" screen comes up (not the Gateway/eMachines screen), hold down the Power Button to shut off the computer. This might force the computer to go in to Windows recovery mode when you restart. Now, turn on the computer, and it should go to a "Windows Diagnostics and Recovery" page. Choose Diagnose the Problem or whatever it says, follow the instructions.
Good luck.
Jan 14, 2018 | Gateway Computers & Internet
I got a blue screen And the computer shut down. I restarted it and I googled how to get rid of the blue screen and I was told to clean the registry. My antivirus has a registry cleaner so I ran it and it...
start your computer in safe mode ,run auto run manager (download it first from internet ) stop unwanted programs from list , then open task manager , open process list , delete unwanted user process , then open run, type regedit , click export in file option of regit window. Save it on desktop, shut down your computer , run on normally ,click on file that you save on desktop ,click merge to registry. Then it will be fine
Jan 29, 2013 | Computers & Internet
Machine will not feed material thru. Needle goes up and down but I cant pull material thru to catch the stitch
Use a fresh needle and install with flat side facing rear of machine. Is your clutch engaged, after you wound the bobbin? Do you have an owners manual? If not, go online to brother-usa.com and download one for free. It is good to have a copy on hand anyway. Good luck
Sep 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
My machine turns on and then immediately shuts off
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck. Here are the most common symptoms and solutions:
  1. Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill (if equipped) trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The amount of time required to shut down will progressively get shorter.
    Solution: The walking belt is worn. The incline test is the best test for it if you don’t have a way to take a DC amp draw. Put the treadmill at full incline and walk normally. If it takes longer to shut off or does not shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to go for a cheap fix (that we don’t recommend) try lubricating the walking belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
  2. Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required before it shuts down gets progressively shorter.
    Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect the deck for wear too. If you want to go for a cheap fix (that we don’t recommend) try lubricating the walking belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
  3. Symptom: The treadmill shuts down in an intermittent pattern…there is no rhyme or reason to when it will shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or reset it to restart the treadmill.
    Solution: If you get an error code, contact us info@fitnessgt.com with the code and make and model and we will try to help you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or some call it a console.
Feb 18, 2010 | Exercise & Fitness
Have HP mini notebook. everytime im on the
Sounds like spyware / malware i would use an online scanner like Eset or a program like Malwarebytes.
also to stop the computer from restarting open the command prompt window (start menu, click run, type cmd, click ok...) type "shutdown.exe /a" without the "" and there is a space between exe and /a this will abort the shutdown.
Jan 22, 2010 | HP Pavilion 110-1030NR Notebook
System shutdown message pop up and shut down and restart computer
Jan 22, 2010 | Computers & Internet
Cant play music thru my computer, has trojan virus and when try to fix it...all music erased!!!!
first off get rid of the virus try using a website called trend micro and using there online scan to get rid of it or download a copy of avg antivirus and use that after you get rid of the viruses then you might ba able to play music on your computer
Sep 22, 2009 | Audio Players & Recorders
Belkin f5d8236-4 router to an access point and cant change back
On the side of the router there is a small reset key, that will restart it.. if you are talking about reseting the software then you have to get into the routers homepage. Let me know if that is what you are talking about and I'll walk you thru it..but the hard reset should do it..
Jun 05, 2009 | Belkin Computers & Internet
Cant connect to internet
put this # at DNS entry 4.2.2.2 and 4.2.2.1
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Printer queue is blocked
Easy, but it will reset all print jobs.
Goto Control Panels.
Open Administration Tools
Open Services
Find Printer Spooler
-Right click and choose restart
Nov 13, 2007 | HP DeskJet 9800 InkJet Printer
Dell Latitude D600 Notebook Logo
67 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
