Question about KitchenAid KGSA906P Gas Kitchen Range
Bake function doesn't work, broil works
I have KitchenAid Gas Range Model YKGST307HS4 (Canadian). When I turn on the Bake/Convection Bake on oven, the display goes to PrE (preheat mode) but the oven does not heat up. The ceramic igniters are cold, there is no smell or sound of gas. The Fan works fine. It works fine in Broil mode. The range top works properly, so there is gas and electric. P.S. All suggestions welcome. How can I find/get a schematic? Thank you in advance for your help.
  • Pramod Patel Mar 29, 2007
    YKGST307HS4 is the same as model KGST307 Gas (Stainless Steel) Range found on the list.
  • Anonymous Nov 19, 2008
    I have a KitchenAid gas stove (not sure on the model type) the bake function is not working however broil is working. A few people said I may need a new element. Has anyone had this problem, got a new element & did it fix the problem??
3 Suggested Answers
  • 183 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
if this cooker is fitted with a clock check that it is not set to delay start mode(auto) if it is reset clock and this will resolve problem
Posted on Jul 28, 2007
supertech6
  • 513 Answers
SOURCE: I have a two ear old Kitchenaid gas range
You will need a new igniter module. The igniter module is told to spark by the control panel. There is also a flame detection for electronic start and that could be bad too.
Posted on Apr 16, 2010
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Aid Gas oven will not turn on
you nee a new ignitor for the bake part of the oven. they are on sale for 20.00 dollars, do it your self, remove bottom plate, and you will see ignitor on back of range attached to gas line.
Sep 22, 2009 | KitchenAid Kitchen Ranges
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
Broiler
can you hear the convection fan motor turn on? if not that would be your problem.
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven not working
Check continuity on gas valve. the middle connector is common, upper is broil and bottom is bake. Resistance between common and bake should be about the same as between common and broil. I believe you'll need to set the ohmmeter to KOhms (or x1000.
If no continuity between any of the connectors - replace gas valve (not much fun, and part is expensive).
Jan 21, 2008 | KitchenAid KGRC707 Gas Kitchen Range
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Open Questions:
KitchenAid KGSA906P Gas Kitchen Range Logo
109 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Jacques Valiquette
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
