Question about Asko D1716 Built-in Dishwasher
Viking (made by ASKO) Dishwasher Problem
I have had this unit (all Stainless on the inside) for 4 years with no problems, until it recently just stopped working correctly.
No complete function, starting with no lights/indication on the control panel (top of door)at any time. With the door open, pressing the On/Off button on the left produces the following: The pump runs, pumping water into the basin, at the same time, the soap door release repaeatedly actuates, and there is a hum/buzz. The only way to stop this is to depress the On/Off button again. Note, at no time during this activity are any of the lights illuminated.
Hope you can help, Thanks - Mike
  • 4,655 Answers
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Posted on Feb 01, 2009
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Sep 11, 2008 | Viking 42 in Built In Professional...
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Installation & question I have an opportunity to purchase
Do not buy. Viking dishwashers are made by Asko and are prone to the same issues, which are numerous; if you have the cash go for Miele.
Jun 01, 2008 | Viking 24 in. Professional Series VUD040...
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
VUD 141
Just click the handle to start the cycle and let drain.  Then just before it starts, turn it off.
Feb 17, 2008 | Viking 24 in. Professional Series VUD040...
ASKO D1716 - blue tinge to stainless
Use any stainless pots cleaner to gat the shine back.
Nov 08, 2007 | Asko D1716 Built-in Dishwasher
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Asko D1716 Built-in Dishwasher Logo
396 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
