Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Printer shows offline/Scanner has no destination list
I have an aficio 1515mf printer/scanner/fax. The printer won't print and it shows offline. I don't know how to get it back online. The scanner shows no destination list and will not let me scan documents.
  • 3 more comments
  • cleverlykids Jan 05, 2009
    I was able to get my printer to start printing. So that's no longer a problem. I'm using an ethernet connection. The problem I have now is that is says updating destination list failed. I can't enter a location to send the scan.
  • cleverlykids Jan 12, 2009
    Joe,
    I need to be able to scan the data and have it go to my computer scan list. I can then attach the scan to my email. Do you know how to add my computer as the destination?
    sorry I'm not very good with computers. I think I understand how to enter the ip address in a browser, just don't know how to get the ip address for the pinter???
  • remmlaw May 04, 2009
    About once a month my comcast high speed internet connection fails and when I reset the modum my ethernet connected Ricoh Aficio 1515 MF cannot re-establish the connection to my computer. The Ricoh desplay says: "No destination is programmed for specified number."
    IKON programmed the Ricoh to scan documents to a "scans" folder on my computer rather than to e-mail for client privancy reasons. When a document is scanned, I select the "ABC" button berore pressing "start." It worked fine for three years with Cox high speed internet access, but after I moved to another state about a year ago, this problem surfaced and IKON does not have a solution other than having the Ricoh technician with whom he communicates by phone take control of my computer and reprogram it.
  • docusultant May 11, 2010
    are you printing thru USB or ethernet?
    If network have you given the device and ip address
  • 58 Answers
    Sniper:
  • 86 Answers
You must program the email addresses in the machine address book, so that you will have a destination list to scan to email.
You can also try to scan by pressing the Scanner button to access the scanner function and input the email address manually by selecting manual, and then press the Start button to scan the document.
Joe
Posted on Jan 10, 2009
Ricoh Aficio MP C6000 Printer Offline
check weather u have connected all cables properly
then check for your printer driver
after checking if everything is proper then right click on mycomputer select manage then serch for the installed driver then right click on pirticular driver go to properties then select driver tab then select rollback option if this dosent works then go to control pannel then go to printer n scanner option delet the installed printer and add it again
Jul 02, 2012 | Ricoh Aficio MP-C6000
Destination list cannot be used now ricoh aficio c2800
If you are using an LDAP server to provide the destination, you may not have the Search Conditions programmed correctly.
Feb 27, 2012 | Ricoh Aficio 1515MF All-In-One Laser...
How do you scan with the Ricoh Aficio 1515mf. I don't have instruction manual.
scanner button, put the document and choose the user. In the end you click on the green button to start
Jan 11, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
I have a ricoh Aficio 1515mf. I have trouble sending a fax. I press the fax botton and then I press the numbers (fax number). But is not sending anything. I don't have a manual. What am I doing wrong?
Do you hit Start after typing in the number? You have to hit the Start button (the green button on the right hand side) in order to send the fax once you've input the destination.
May 28, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
My mp 2000 ricoh scanner and printer only works for printing, not for scanning
if you have not set it up to scan you need to do so. go to ricoh.com then americas then knowledge base then white papers. and look for how to set up scanning to email or to folder.
Jan 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Richo 1515 MF Error message: 12320 couldn't find the scanner.
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
Feb 27, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
5,675 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
